주요 콘텐츠로 건너뛰기
Sony Cyber-shot DSC-W800 LCD Screen Replacement
필요한 것
  1. Sony Cyber-shot DSC-W800 LCD Screen Replacement, Button Board: 1 단계, 이미지 1/3 Sony Cyber-shot DSC-W800 LCD Screen Replacement, Button Board: 1 단계, 이미지 2/3 Sony Cyber-shot DSC-W800 LCD Screen Replacement, Button Board: 1 단계, 이미지 3/3
    • Remove the five 4.0 mm Phillips #000 screws on the back panel.
  2. Sony Cyber-shot DSC-W800 LCD Screen Replacement: 2 단계, 이미지 1/2 Sony Cyber-shot DSC-W800 LCD Screen Replacement: 2 단계, 이미지 2/2
    • Using the Spudger, remove the back panel from the device.
    • The loose piece circled in the picture will most likely fall off the camera housing.
  3. Sony Cyber-shot DSC-W800 LCD Screen Replacement: 3 단계, 이미지 1/3 Sony Cyber-shot DSC-W800 LCD Screen Replacement: 3 단계, 이미지 2/3 Sony Cyber-shot DSC-W800 LCD Screen Replacement: 3 단계, 이미지 3/3
    • Remove the two 2.15mm Phillips #000 screws from the circuit board.
    • Gently pull on the ribbon wire from ZIF connector with the tweezers to remove the button board.
    • Ribbon wires can easily be damaged.
  4. Sony Cyber-shot DSC-W800 LCD Screen Replacement, LCD Screen: 4 단계, 이미지 1/1
    • Remove the four 3.75 mm Phillips #000 screws from the LCD back panel.
  5. Sony Cyber-shot DSC-W800 LCD Screen Replacement: 5 단계, 이미지 1/1
    • Lift the back panel and separate the LCD Screen by prying it up.
    • Remove the back panel.
  6. Sony Cyber-shot DSC-W800 LCD Screen Replacement: 6 단계, 이미지 1/2 Sony Cyber-shot DSC-W800 LCD Screen Replacement: 6 단계, 이미지 2/2
    • Gently pull on the ribbon wire disconnecting from the ZIF connector (connecting the LCD screen to the motherboard) with the tweezers.
    • Ribbon wires can be easily damaged.
결론
다른 3명이 해당 안내서를 완성하였습니다.
Thomas Campo
회원 가입일: 02/09/16
788 평판
안내서 4개 작성하였습니다
USF Tampa, Team 17-5, Blackwell Winter 2016 USF Tampa, Team 17-5, Blackwell Winter 2016 회원
USFT-BLACKWELL-W16S17G5
5 회원들
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 4
30일 전: 16
전체 시간: 2,437
