주요 콘텐츠로 건너뛰기
Sony Cyber-shot DSC-W800 Lens Replacement
필요한 것
  1. Sony Cyber-shot DSC-W800 Lens Replacement, Button Board: 1 단계, 이미지 3개 중 1개 Sony Cyber-shot DSC-W800 Lens Replacement, Button Board: 1 단계, 이미지 3개 중 2개 Sony Cyber-shot DSC-W800 Lens Replacement, Button Board: 1 단계, 이미지 3개 중 3개
    • Remove the five 4.0 mm Phillips #000 screws on the back panel.
  2. Sony Cyber-shot DSC-W800 Lens Replacement: 2 단계, 이미지 2개 중 1개 Sony Cyber-shot DSC-W800 Lens Replacement: 2 단계, 이미지 2개 중 2개
    • Using the Spudger, remove the back panel from the device.
    • The loose piece circled in the picture will most likely fall off the camera housing.
  3. Sony Cyber-shot DSC-W800 Lens Replacement: 3 단계, 이미지 3개 중 1개 Sony Cyber-shot DSC-W800 Lens Replacement: 3 단계, 이미지 3개 중 2개 Sony Cyber-shot DSC-W800 Lens Replacement: 3 단계, 이미지 3개 중 3개
    이 단계에 사용된 도구:
    • Remove the two 2.15mm Phillips #000 screws from the circuit board.
    • Gently pull on the ribbon wire from ZIF connector with the tweezers to remove the button board.
    • Ribbon wires can easily be damaged.
  4. Sony Cyber-shot DSC-W800 Lens Replacement, LCD Screen: 4 단계, 이미지 1개 중 1개
    • Remove the four 3.75 mm Phillips #000 screws from the LCD back panel.
  5. Sony Cyber-shot DSC-W800 Lens Replacement: 5 단계, 이미지 1개 중 1개
    • Lift the back panel and separate the LCD Screen by prying it up.
    • Remove the back panel.
  6. Sony Cyber-shot DSC-W800 Lens Replacement: 6 단계, 이미지 2개 중 1개 Sony Cyber-shot DSC-W800 Lens Replacement: 6 단계, 이미지 2개 중 2개
    이 단계에 사용된 도구:
    • Gently pull on the ribbon wire disconnecting from the ZIF connector (connecting the LCD screen to the motherboard) with the tweezers.
    • Ribbon wires can be easily damaged.
  7. Sony Cyber-shot DSC-W800 Lens Replacement, Lens: 7 단계, 이미지 2개 중 1개 Sony Cyber-shot DSC-W800 Lens Replacement, Lens: 7 단계, 이미지 2개 중 2개
    • With plastic opening tool, gently pry loose the front panel.
    • Separate front panel from the camera housing.
  8. Sony Cyber-shot DSC-W800 Lens Replacement: 8 단계, 이미지 3개 중 1개 Sony Cyber-shot DSC-W800 Lens Replacement: 8 단계, 이미지 3개 중 2개 Sony Cyber-shot DSC-W800 Lens Replacement: 8 단계, 이미지 3개 중 3개
    이 단계에 사용된 도구:
    • Remove the lens housing by pushing it, from the front, through the housing and lifting it out.
    • Gently pull on the large ribbon wire (connecting the Lens housing to the motherboard via ZIF connector) with the tweezers.
    • Gently pull on the small ribbon wire (connecting the Lens housing to the motherboard) with the tweezers.
    • Be careful not to damage either of the ribbon wires.
결론
다른 4명이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Thomas Campo
회원 가입일: 02/09/16
827 평판
안내서 4개를 작성함
USF Tampa, Team 17-5, Blackwell Winter 2016 USF Tampa, Team 17-5, Blackwell Winter 2016 회원
USFT-BLACKWELL-W16S17G5
5 회원들
안내서 5개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 25
지난 30일: 52
전체 시간: 4,918
