주요 콘텐츠로 건너뛰기
Sony Cyber-shot DSC-WX100 Lens Assembly Replacement
필요한 것
  1. Sony Cyber-shot DSC-WX100 Lens Assembly Replacement, Battery: 1 단계, 이미지 1/1
    • Open the flap indicated to allow access to the battery slot.
    • The gray switch indicated has to be moved to the right in order to release the flap.
  2. Sony Cyber-shot DSC-WX100 Lens Assembly Replacement: 2 단계, 이미지 1/1
    • If the old battery is still in the slot, then make sure the camera is turned off prior to removal.
    • If there is a battery currently in the slot, remove by first pulling downwards on the blue component. This will allow you to remove the battery from the slot.
  3. Sony Cyber-shot DSC-WX100 Lens Assembly Replacement, Outer Casing: 3 단계, 이미지 1/3 Sony Cyber-shot DSC-WX100 Lens Assembly Replacement, Outer Casing: 3 단계, 이미지 2/3 Sony Cyber-shot DSC-WX100 Lens Assembly Replacement, Outer Casing: 3 단계, 이미지 3/3
    • Remove all of the 1mm screws using a Philips #000 Screwdriver.
    • Remover the rest of the screws (2mm) from the camera covers using a Phillips #000 Screwdriver.
  4. Sony Cyber-shot DSC-WX100 Lens Assembly Replacement: 4 단계, 이미지 1/2 Sony Cyber-shot DSC-WX100 Lens Assembly Replacement: 4 단계, 이미지 2/2
    • Use the plastic opening tool to gently remove the front and back plates of the camera.
  5. Sony Cyber-shot DSC-WX100 Lens Assembly Replacement: 5 단계, 이미지 1/2 Sony Cyber-shot DSC-WX100 Lens Assembly Replacement: 5 단계, 이미지 2/2
    • Use a plastic opening tool to gently release the two indicated tabs.
    • Pull up on the lower end of the plate. Lift it so that the plate is uninhibited by the indicated bump.
    • Pull away from the camera at the end of the metal plate with the blue circuits to then remove the plate from the rest of the camera.
    • For help with this step, refer to the video.
  6. Sony Cyber-shot DSC-WX100 Lens Assembly Replacement: 7 단계, 이미지 1/3 Sony Cyber-shot DSC-WX100 Lens Assembly Replacement: 7 단계, 이미지 2/3 Sony Cyber-shot DSC-WX100 Lens Assembly Replacement: 7 단계, 이미지 3/3
    • Remove this screw (1mm) with the Phillips #000 Screwdriver.
    • Gently lift the LCD screen component from the metal plate.
    • Remove the metal plate that was underneath the LCD screen from the camera.
  7. Sony Cyber-shot DSC-WX100 Lens Assembly Replacement: 8 단계, 이미지 1/3 Sony Cyber-shot DSC-WX100 Lens Assembly Replacement: 8 단계, 이미지 2/3 Sony Cyber-shot DSC-WX100 Lens Assembly Replacement: 8 단계, 이미지 3/3
    • Peel back the copper sheet.
    • Unscrew the three marked screws (2mm) using a Phillips #000 Screwdriver.
    • Remove the panel attached by said screws.
  8. Sony Cyber-shot DSC-WX100 Lens Assembly Replacement: 9 단계, 이미지 1/1
    • Peel back both the copper sheet and the black tape underneath the panel to expose the connection port.
  9. Sony Cyber-shot DSC-WX100 Lens Assembly Replacement: 10 단계, 이미지 1/3 Sony Cyber-shot DSC-WX100 Lens Assembly Replacement: 10 단계, 이미지 2/3 Sony Cyber-shot DSC-WX100 Lens Assembly Replacement: 10 단계, 이미지 3/3
    • Use a plastic opening tool to pry the black bar upwards.
    • Pull the image sensor out after the black tab is released.
  10. Sony Cyber-shot DSC-WX100 Lens Assembly Replacement, Lens Assembly: 11 단계, 이미지 1/1
    • Peel back the black tape to reveal the connection port shown below.
  11. Sony Cyber-shot DSC-WX100 Lens Assembly Replacement: 12 단계, 이미지 1/3 Sony Cyber-shot DSC-WX100 Lens Assembly Replacement: 12 단계, 이미지 2/3 Sony Cyber-shot DSC-WX100 Lens Assembly Replacement: 12 단계, 이미지 3/3
    • Pry the black bar upwards with a plastic opening tool.
    • Remove the wire sheet from the connection port.
결론
Matthew
회원 가입일: 03/18/15
583 평판
안내서 4개 작성하였습니다
Michigan Tech, Team 1-9, Lauer Spring 2015 Michigan Tech, Team 1-9, Lauer Spring 2015 회원
MTU-LAUER-S15S1G9
2 회원들
안내서 6개 작성하였습니다
댓글 한 개
could i also replace the lens of my wx220 using these instructions?
Vinicius Lupas - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 3
30일 전: 7
전체 시간: 1,509
