주요 콘텐츠로 건너뛰기
Sony Cyber-shot DSC-WX100 Outer Casing Replacement
필요한 것
  1. Sony Cyber-shot DSC-WX100 Outer Casing Replacement, Battery: 1 단계, 이미지 1/1
    • Open the flap indicated to allow access to the battery slot.
    • The gray switch indicated has to be moved to the right in order to release the flap.
  2. Sony Cyber-shot DSC-WX100 Outer Casing Replacement: 2 단계, 이미지 1/1
    • If the old battery is still in the slot, then make sure the camera is turned off prior to removal.
    • If there is a battery currently in the slot, remove by first pulling downwards on the blue component. This will allow you to remove the battery from the slot.
  3. Sony Cyber-shot DSC-WX100 Outer Casing Replacement, Outer Casing: 3 단계, 이미지 1/3 Sony Cyber-shot DSC-WX100 Outer Casing Replacement, Outer Casing: 3 단계, 이미지 2/3 Sony Cyber-shot DSC-WX100 Outer Casing Replacement, Outer Casing: 3 단계, 이미지 3/3
    • Remove all of the 1mm screws using a Philips #000 Screwdriver.
    • Remover the rest of the screws (2mm) from the camera covers using a Phillips #000 Screwdriver.
  4. Sony Cyber-shot DSC-WX100 Outer Casing Replacement: 4 단계, 이미지 1/2 Sony Cyber-shot DSC-WX100 Outer Casing Replacement: 4 단계, 이미지 2/2
    • Use the plastic opening tool to gently remove the front and back plates of the camera.
  5. Sony Cyber-shot DSC-WX100 Outer Casing Replacement: 5 단계, 이미지 1/2 Sony Cyber-shot DSC-WX100 Outer Casing Replacement: 5 단계, 이미지 2/2
    • Use a plastic opening tool to gently release the two indicated tabs.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Matthew
회원 가입일: 03/18/15
583 평판
안내서 4개 작성하였습니다
Michigan Tech, Team 1-9, Lauer Spring 2015 Michigan Tech, Team 1-9, Lauer Spring 2015 회원
MTU-LAUER-S15S1G9
2 회원들
안내서 6개 작성하였습니다
댓글 한 개
Where I can buy the Outer Casing..¿??
ING CHARLY - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 6
전체 시간: 827
