주요 콘텐츠로 건너뛰기
Sony Cyber-shot DSC-WX220 Lens Assembly Replacement
필요한 것
  1. Sony Cyber-shot DSC-WX220 Lens Assembly Replacement, Battery: 1 단계, 이미지 1개 중 1개
    • Slide the gray switch from lock to open position.
  2. Sony Cyber-shot DSC-WX220 Lens Assembly Replacement: 2 단계, 이미지 2개 중 1개 Sony Cyber-shot DSC-WX220 Lens Assembly Replacement: 2 단계, 이미지 2개 중 2개
    • Pull down on the blue tab to release the battery.
  3. Sony Cyber-shot DSC-WX220 Lens Assembly Replacement, Outer Case: 3 단계, 이미지 3개 중 1개 Sony Cyber-shot DSC-WX220 Lens Assembly Replacement, Outer Case: 3 단계, 이미지 3개 중 2개 Sony Cyber-shot DSC-WX220 Lens Assembly Replacement, Outer Case: 3 단계, 이미지 3개 중 3개
    • Use a PH00 screwdriver to remove the five 3.5 mm screws.
    • Use a PH00 screwdriver to remove the two 2.5 mm screws.
  4. Sony Cyber-shot DSC-WX220 Lens Assembly Replacement: 4 단계, 이미지 2개 중 1개 Sony Cyber-shot DSC-WX220 Lens Assembly Replacement: 4 단계, 이미지 2개 중 2개
    • Pry apart the case gently using a plastic opening tool.
  5. Sony Cyber-shot DSC-WX220 Lens Assembly Replacement, Lens Assembly: 5 단계, 이미지 1개 중 1개
    • Pry back the panel to the right of the screen using a plastic opening tool.
  6. Sony Cyber-shot DSC-WX220 Lens Assembly Replacement: 6 단계, 이미지 1개 중 1개
    • Working on the left side of the screen, pry the metal panel off from the motherboard housing using a plastic opening tool.
  7. Sony Cyber-shot DSC-WX220 Lens Assembly Replacement: 7 단계, 이미지 1개 중 1개
    • Pull out the ZIF cable from the motherboard.
    • When removing the ZIF cable, pull it straight out to avoid damaging the cable.
  8. Sony Cyber-shot DSC-WX220 Lens Assembly Replacement: 8 단계, 이미지 2개 중 1개 Sony Cyber-shot DSC-WX220 Lens Assembly Replacement: 8 단계, 이미지 2개 중 2개
    • Unpin the ZIF cable by lifting the cable towards the top of the camera while pulling up towards yourself.
    • Pull the ZIF cable out.
  9. Sony Cyber-shot DSC-WX220 Lens Assembly Replacement: 9 단계, 이미지 1개 중 1개
    • Lift the lens out of the case.
    • Pull out the ZIF cable.
결론
다른 2명이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Kate Glazer
회원 가입일: 03/20/18
621 평판
안내서 5개를 작성함
IUPUI, Team S6-G3, Baechle Spring 2018 IUPUI, Team S6-G3, Baechle Spring 2018 회원
IUPUI-BAECHLE-S18S6G3
3 회원들
안내서 5개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 5
지난 30일: 44
전체 시간: 1,193
