주요 콘텐츠로 건너뛰기
Sony Cyber-shot DSC-WX220 Screen Replacement
필요한 것
  1. Sony Cyber-shot DSC-WX220 Screen Replacement, Battery: 1 단계, 이미지 1/1
    • Slide the gray switch from lock to open position.
  2. Sony Cyber-shot DSC-WX220 Screen Replacement: 2 단계, 이미지 1/2 Sony Cyber-shot DSC-WX220 Screen Replacement: 2 단계, 이미지 2/2
    • Pull down on the blue tab to release the battery.
  3. Sony Cyber-shot DSC-WX220 Screen Replacement, Outer Case: 3 단계, 이미지 1/3 Sony Cyber-shot DSC-WX220 Screen Replacement, Outer Case: 3 단계, 이미지 2/3 Sony Cyber-shot DSC-WX220 Screen Replacement, Outer Case: 3 단계, 이미지 3/3
    • Use a PH00 screwdriver to remove the five 3.5 mm screws.
    • Use a PH00 screwdriver to remove the two 2.5 mm screws.
  4. Sony Cyber-shot DSC-WX220 Screen Replacement: 4 단계, 이미지 1/2 Sony Cyber-shot DSC-WX220 Screen Replacement: 4 단계, 이미지 2/2
    • Pry apart the case gently using a plastic opening tool.
  5. Sony Cyber-shot DSC-WX220 Screen Replacement, Screen: 5 단계, 이미지 1/1
    • Pry back the panel to the right of the screen using a plastic opening tool.
  6. Sony Cyber-shot DSC-WX220 Screen Replacement: 6 단계, 이미지 1/1
    • Working on the left side of the screen, pry the metal panel off from the motherboard housing using a plastic opening tool.
  7. Sony Cyber-shot DSC-WX220 Screen Replacement: 7 단계, 이미지 1/1
    • Pull out the ZIF cable from the motherboard.
    • When removing the ZIF cable, pull it straight out to avoid damaging the cable.
  8. Sony Cyber-shot DSC-WX220 Screen Replacement: 8 단계, 이미지 1/1
    • Lift the LCD screen from it's metal housing.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Kate Glazer
회원 가입일: 03/20/18
621 평판
안내서 5개 작성하였습니다
IUPUI, Team S6-G3, Baechle Spring 2018 IUPUI, Team S6-G3, Baechle Spring 2018 회원
IUPUI-BAECHLE-S18S6G3
3 회원들
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 11
전체 시간: 948
