주요 콘텐츠로 건너뛰기
Sony Cyber-shot DSC-WX350 Flash Assembly Replacement
필요한 것
  1. Sony Cyber-shot DSC-WX350 Flash Assembly Replacement, Flash Assembly: 1 단계, 이미지 1/3 Sony Cyber-shot DSC-WX350 Flash Assembly Replacement, Flash Assembly: 1 단계, 이미지 2/3 Sony Cyber-shot DSC-WX350 Flash Assembly Replacement, Flash Assembly: 1 단계, 이미지 3/3
    • Remove 6 black Phillips 4 mm screws using the J00 head screwdriver tip from the sides and bottom of top cover.
  2. Sony Cyber-shot DSC-WX350 Flash Assembly Replacement: 2 단계, 이미지 1/1
    • Remove the black Phillips 4 mm screw using the J00 head screwdriver tip from inside the battery inclosure.
  3. Sony Cyber-shot DSC-WX350 Flash Assembly Replacement: 3 단계, 이미지 1/2 Sony Cyber-shot DSC-WX350 Flash Assembly Replacement: 3 단계, 이미지 2/2
    • Use the plastic opening tool to take back cover off. Then take out the LCD screen with your hand.
  4. Sony Cyber-shot DSC-WX350 Flash Assembly Replacement: 4 단계, 이미지 1/1
    • Now take the control wheel board out with your hand.
  5. Sony Cyber-shot DSC-WX350 Flash Assembly Replacement: 5 단계, 이미지 1/1
    • On the left side of the camera, pull the LCD off the back plate.
    • There will be a ZIF connector by the control wheel, release the connector and remove the LCD.
  6. Sony Cyber-shot DSC-WX350 Flash Assembly Replacement: 6 단계, 이미지 1/2 Sony Cyber-shot DSC-WX350 Flash Assembly Replacement: 6 단계, 이미지 2/2
    • Remove silver Phillips 4 mm screws using the J00 head screwdriver tip from the metal cover. Once done take the metal cover off with your hands.
  7. Sony Cyber-shot DSC-WX350 Flash Assembly Replacement: 7 단계, 이미지 1/3 Sony Cyber-shot DSC-WX350 Flash Assembly Replacement: 7 단계, 이미지 2/3 Sony Cyber-shot DSC-WX350 Flash Assembly Replacement: 7 단계, 이미지 3/3
    • Using your finger open take off the three zifs.
  8. Sony Cyber-shot DSC-WX350 Flash Assembly Replacement: 8 단계, 이미지 1/2 Sony Cyber-shot DSC-WX350 Flash Assembly Replacement: 8 단계, 이미지 2/2
    • Use your hand to take out the lens assembly. Then take out the motherboard assembly with your hand.
  9. Sony Cyber-shot DSC-WX350 Flash Assembly Replacement: 9 단계, 이미지 1/3 Sony Cyber-shot DSC-WX350 Flash Assembly Replacement: 9 단계, 이미지 2/3 Sony Cyber-shot DSC-WX350 Flash Assembly Replacement: 9 단계, 이미지 3/3
    • Remove the silver Phillips 4 mm screws using the J00 head screwdriver tip from the metal piece and remove the 4mm screws from the metal piece lining the lens assembly hole.
  10. Sony Cyber-shot DSC-WX350 Flash Assembly Replacement: 10 단계, 이미지 1/2 Sony Cyber-shot DSC-WX350 Flash Assembly Replacement: 10 단계, 이미지 2/2
    • Grab the top of the camera and take it out. Then grab the flash assembly and slide it out.
결론
다른 4명이 해당 안내서를 완성하였습니다.
Matt Garthwaite
회원 가입일: 05/22/17
125 평판
안내서 1개 작성함
IUPUI, Team S1-G1, Wilson Summer 2017 IUPUI, Team S1-G1, Wilson Summer 2017 회원
IUPUI-WILSON-SU17S1G1
4 회원들
안내서 3개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 8
30일 전: 31
전체 시간: 1,679
