주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Sony Cyber-shot DSC-WX350 Lens Assembly Replacement
필요한 것
    1. Sony Cyber-shot DSC-WX350 Lens Assembly Replacement, Lens Assembly: 1 단계, 이미지 3개 중 1개 Sony Cyber-shot DSC-WX350 Lens Assembly Replacement, Lens Assembly: 1 단계, 이미지 3개 중 2개 Sony Cyber-shot DSC-WX350 Lens Assembly Replacement, Lens Assembly: 1 단계, 이미지 3개 중 3개
      • Use the J00 screwdriver to take out the four 3mm black screws on the bottom and both sides of the camera.
      댓글 쓰기
    2. Sony Cyber-shot DSC-WX350 Lens Assembly Replacement: 2 단계, 이미지 1개 중 1개
      • On the bottom of the camera slide the button over to open the battery case. Inside the battery opening use the J00 screwdriver to take out the single 3mm black screw.
      댓글 쓰기
    3. Sony Cyber-shot DSC-WX350 Lens Assembly Replacement: 3 단계, 이미지 1개 중 1개
      • Use the J00 screwdriver to take out the single 3mm black screw on the left side of the camera .
      댓글 쓰기
    4. Sony Cyber-shot DSC-WX350 Lens Assembly Replacement: 4 단계, 이미지 2개 중 1개 Sony Cyber-shot DSC-WX350 Lens Assembly Replacement: 4 단계, 이미지 2개 중 2개
      • Use the plastic opening tool to pry open the back cover off.
      댓글 쓰기
    5. Sony Cyber-shot DSC-WX350 Lens Assembly Replacement: 5 단계, 이미지 1개 중 1개
      • Use your fingers to slide out the controller wheel board 's lower end, then unhook the other end.
      댓글 쓰기
    6. Sony Cyber-shot DSC-WX350 Lens Assembly Replacement: 6 단계, 이미지 1개 중 1개
      • Take the LCD off by undoing the zif and sliding it out.
      댓글 쓰기
    7. Sony Cyber-shot DSC-WX350 Lens Assembly Replacement: 7 단계, 이미지 2개 중 1개 Sony Cyber-shot DSC-WX350 Lens Assembly Replacement: 7 단계, 이미지 2개 중 2개
      • Once the LCD is off use the J00 screwdriver to take out the two 3mm silver screws. Once the screws are taken out pull off the piece with your fingers.
      댓글 쓰기
    8. Sony Cyber-shot DSC-WX350 Lens Assembly Replacement: 8 단계, 이미지 3개 중 1개 Sony Cyber-shot DSC-WX350 Lens Assembly Replacement: 8 단계, 이미지 3개 중 2개 Sony Cyber-shot DSC-WX350 Lens Assembly Replacement: 8 단계, 이미지 3개 중 3개
      • Now take out the 3 zifs by first opening the zif latch with your fingers and then sliding it out.
      댓글 쓰기
    9. Sony Cyber-shot DSC-WX350 Lens Assembly Replacement: 9 단계, 이미지 1개 중 1개
      • Carefully remove the lens assembly from the camera.
      댓글 쓰기
    10. Sony Cyber-shot DSC-WX350 Lens Assembly Replacement: 10 단계, 이미지 2개 중 1개 Sony Cyber-shot DSC-WX350 Lens Assembly Replacement: 10 단계, 이미지 2개 중 2개
      • In order to access the CCD, loosen the 3 screws holding its metal lid.
      • In order to access the lens mechanics, take out the 4 3mm screws on the edge of the lid, then the single 3 mm screw next to the motor.
      댓글 쓰기
    11. Sony Cyber-shot DSC-WX350 Lens Assembly Replacement: 11 단계, 이미지 1개 중 1개
      • Carefully tear off the ribbon glued to the plastic.
      댓글 쓰기
    12. Sony Cyber-shot DSC-WX350 Lens Assembly Replacement: 12 단계, 이미지 2개 중 1개 Sony Cyber-shot DSC-WX350 Lens Assembly Replacement: 12 단계, 이미지 2개 중 2개
      • Pull out the cogwheel with the drive unit.
      • Now you can access the lens inner mechanics. You might wanna cover the CCD and the inner lens opening with tape to prevent dust from entering before you try to clean anything.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 4명이 해당 안내서를 완성하였습니다.
작성자
5다른 기여자 명과 함께
Joshua R Hammel
회원 가입일: 05/22/17
283 평판
안내서 1개를 작성함
IUPUI, Team S1-G1, Wilson Summer 2017 IUPUI, Team S1-G1, Wilson Summer 2017 회원
IUPUI-WILSON-SU17S1G1
4 회원들
안내서 30개를 작성함
2가이드 댓글
Hi, I think on my sensor chip is some dust. Is it possible to clean that or is it one unit with lens? There is no picture about this detail….
Arno - 답글 공유
Hi there, does anyone know who I could go to to fix the lens (replace them) on my Sony wx-350 camera Thank you!
Joshua O'Brien - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 30
지난 30일: 147
전체 시간: 6,499
