주요 콘텐츠로 건너뛰기
Sony Cyber-shot DSC-WX350 Motherboard Replacement
필요한 것
  1. Sony Cyber-shot DSC-WX350 Motherboard Replacement, Motherboard: 1 단계, 이미지 1/3 Sony Cyber-shot DSC-WX350 Motherboard Replacement, Motherboard: 1 단계, 이미지 2/3 Sony Cyber-shot DSC-WX350 Motherboard Replacement, Motherboard: 1 단계, 이미지 3/3
    • Remove 6 Phillips 4mm screws from the bottom and sides of the device.
    • Remove the 1 Phillips 4mm screw from under the battery cover.
  2. Sony Cyber-shot DSC-WX350 Motherboard Replacement: 2 단계, 이미지 1/1
    • Insert the plastic opening tool between the back cover and the bottom plate. Gently pry the cover off.
  3. Sony Cyber-shot DSC-WX350 Motherboard Replacement: 3 단계, 이미지 1/2 Sony Cyber-shot DSC-WX350 Motherboard Replacement: 3 단계, 이미지 2/2
    • Use your fingers to slide out the controller wheel board.
  4. Sony Cyber-shot DSC-WX350 Motherboard Replacement: 4 단계, 이미지 1/1
    • On the left side of the camera, pull the LCD off the back plate.
    • There will be a ZIF connector by the control wheel, release the connector and remove the LCD.
  5. Sony Cyber-shot DSC-WX350 Motherboard Replacement: 5 단계, 이미지 1/2 Sony Cyber-shot DSC-WX350 Motherboard Replacement: 5 단계, 이미지 2/2
    • Once the LCD is off use the J00 screwdriver to take out the two 4mm silver screws. Once the screws are taken out pull off the piece with your fingers.
  6. Sony Cyber-shot DSC-WX350 Motherboard Replacement: 6 단계, 이미지 1/1
    • Remove the three ZIFs connected to the motherboard. The top is found under a piece of tape.
  7. Sony Cyber-shot DSC-WX350 Motherboard Replacement: 7 단계, 이미지 1/2 Sony Cyber-shot DSC-WX350 Motherboard Replacement: 7 단계, 이미지 2/2
    • Remove the lens assembly and motherboard from the front of the case.
    • The lens assembly should separate when removing the front.
  8. Sony Cyber-shot DSC-WX350 Motherboard Replacement: 8 단계, 이미지 1/3 Sony Cyber-shot DSC-WX350 Motherboard Replacement: 8 단계, 이미지 2/3 Sony Cyber-shot DSC-WX350 Motherboard Replacement: 8 단계, 이미지 3/3
    • On the backside of the motherboard, a silver clip is holding the motherboard to the plastic shell. Insert the plastic opening tool under the clip and pry gently until it releases.
결론
Ryan Speitel
회원 가입일: 05/22/17
101 평판
안내서 1개 작성함
IUPUI, Team S1-G1, Wilson Summer 2017 IUPUI, Team S1-G1, Wilson Summer 2017 회원
IUPUI-WILSON-SU17S1G1
4 회원들
안내서 3개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 2
30일 전: 37
전체 시간: 1,483
