주요 콘텐츠로 건너뛰기
Sony Cyber-shot DSC-WX80 Battery Replacement
필요한 것
  1. Sony Cyber-shot DSC-WX80 Battery Replacement, Battery: 1 단계, 이미지 1/3 Sony Cyber-shot DSC-WX80 Battery Replacement, Battery: 1 단계, 이미지 2/3 Sony Cyber-shot DSC-WX80 Battery Replacement, Battery: 1 단계, 이미지 3/3
    • Begin by removing all six #00 screws holding the outer chassis together with the Phillips #00 Precision Screwdriver.
    • Remember to keep track of all screws as they are small and very easy to lose
  2. Sony Cyber-shot DSC-WX80 Battery Replacement: 2 단계, 이미지 1/3 Sony Cyber-shot DSC-WX80 Battery Replacement: 2 단계, 이미지 2/3 Sony Cyber-shot DSC-WX80 Battery Replacement: 2 단계, 이미지 3/3
    • Take note of the small free moving flap near the battery port seen in the first of the three photos. Be sure to store the free moving flap in a safe place.
    • Pry the front cover off gently. Use a plastic opening tool if available.
    • Now pry the back cover off gently, using a plastic opening tool if available.
  3. Sony Cyber-shot DSC-WX80 Battery Replacement: 3 단계, 이미지 1/1
    • Access where the replacement battery will go indicated by the red square in the photo to your left
    • Now insert your new replacement battery
결론
Matthew Schmid
회원 가입일: 04/08/15
425 평판
안내서 2개 작성하였습니다
댓글 2개
Why did you not just open the bottom battery door instead of pulling the camera apart?
Kat - 답글
I am also suprised to know that I should dis-assemble to replace battery. It maybe a joke.
Chung-Suh Ku - 답글
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 5
30일 전: 11
전체 시간: 1,020
