주요 콘텐츠로 건너뛰기
Sony Cyber-shot DSC-WX80 LCD Screen Replacement
필요한 것
  1. Sony Cyber-shot DSC-WX80 LCD Screen Replacement, LCD Screen: 1 단계, 이미지 1/3 Sony Cyber-shot DSC-WX80 LCD Screen Replacement, LCD Screen: 1 단계, 이미지 2/3 Sony Cyber-shot DSC-WX80 LCD Screen Replacement, LCD Screen: 1 단계, 이미지 3/3
    • Begin by removing all six #00 40mm by 10mm black screws holding the outer frame together with the Phillips #00 Precision Screwdriver.
    • Remember to keep track of all screws as they are small and very easy to lose
  2. Sony Cyber-shot DSC-WX80 LCD Screen Replacement: 2 단계, 이미지 1/3 Sony Cyber-shot DSC-WX80 LCD Screen Replacement: 2 단계, 이미지 2/3 Sony Cyber-shot DSC-WX80 LCD Screen Replacement: 2 단계, 이미지 3/3
    • Take note of the small free moving flap near the battery port seen in the first of the three photos. Be sure to store the free moving flap in a safe place.
    • Pry the front cover off gently. Use a plastic opening tool if available.
    • Now pry the back cover off gently, using a plastic opening tool if available.
  3. Sony Cyber-shot DSC-WX80 LCD Screen Replacement: 3 단계, 이미지 1/3 Sony Cyber-shot DSC-WX80 LCD Screen Replacement: 3 단계, 이미지 2/3 Sony Cyber-shot DSC-WX80 LCD Screen Replacement: 3 단계, 이미지 3/3
    • Remove the #00 screw from the right hand side (from the LCD screen side) which is adjacent to the master control dial. Reference the first image.
    • Use a spudger or plastic opening tools to pry up the LCD screen and free the two metal tangs on the left side. Reference the second image.
    • Lift up two more metal tabs held down by a thin red plastic strap on the right (master control dial) side. Reference the third image.
    • The thin red plastic strap is very fragile.
  4. Sony Cyber-shot DSC-WX80 LCD Screen Replacement: 4 단계, 이미지 1/2 Sony Cyber-shot DSC-WX80 LCD Screen Replacement: 4 단계, 이미지 2/2
    이 단계에 사용된 도구:
    구매
    • Using a pair of tweezers, remove the blue ribbon from its connection located toward to the top right of the device. Reference the first image.
    • Using a pair of tweezers, remove the gold ribbon from its connection located to the right of the removed blue ribbon. Reference the second image.
    • Your LCD screen is now removed and you can replace it!
결론
다른 4명이 해당 안내서를 완성하였습니다.
Benjamin Anderson
회원 가입일: 04/08/15
116 평판
안내서 1개 작성함
댓글 2개
Would the wheel be included with the LCD? The wheel on my camera is broken, and I would like to fix/replace it, so should I just order a new LCD screen?
Caleb V. - 답글
The replacement includes just the compatible LDC screen and the connector; the wheel is a separate piece.
The LCD comes naked, meaning that the fancy screen protector with black frame is not provided. It is kind of a sticker which shall be detached from the original LCD and re-attached to the new one. It would have been a good idea to include it within the fix tip.
Jose Luis Martínez - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 6
30일 전: 22
전체 시간: 1,801
