소개
If your camera won't respond when you press the menu button, delete button, or control wheel, use this guide to replace the internal sensory panel.
필요한 것
Make sure the camera is turned off.
Press the ON/OFF button to turn off the camera.
다른 5명이 해당 안내서를 완성하였습니다.
댓글 5개
I have issues when I turn the wheel to change the settings on manual mode. Would this be the same part?
Also, where can I find it? I tried to have it professionally repair and was told it needed the whole board and that it was not available any more. Thanks!
Sam, where did you find parts?
