주요 콘텐츠로 건너뛰기
Sony Cybershot DSC-T5 Plastic Screen Cover Replacement
필요한 것
  1. Sony Cybershot DSC-T5 Plastic Screen Cover Replacement, Plastic Screen Cover: 1 단계, 이미지 1/2 Sony Cybershot DSC-T5 Plastic Screen Cover Replacement, Plastic Screen Cover: 1 단계, 이미지 2/2
    • Push open the sliding cover to access screws.
  2. Sony Cybershot DSC-T5 Plastic Screen Cover Replacement: 2 단계, 이미지 1/3 Sony Cybershot DSC-T5 Plastic Screen Cover Replacement: 2 단계, 이미지 2/3 Sony Cybershot DSC-T5 Plastic Screen Cover Replacement: 2 단계, 이미지 3/3
    • Remove the screws in the red circles.
  3. Sony Cybershot DSC-T5 Plastic Screen Cover Replacement: 3 단계, 이미지 1/3 Sony Cybershot DSC-T5 Plastic Screen Cover Replacement: 3 단계, 이미지 2/3 Sony Cybershot DSC-T5 Plastic Screen Cover Replacement: 3 단계, 이미지 3/3
    • Remove the back cover panel from the rest of the camera.
  4. Sony Cybershot DSC-T5 Plastic Screen Cover Replacement: 4 단계, 이미지 1/2 Sony Cybershot DSC-T5 Plastic Screen Cover Replacement: 4 단계, 이미지 2/2
    • Push the plastic cover out of the panel.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
John Aust
회원 가입일: 03/24/15
53 평판
안내서 2개 작성하였습니다
UMass Dartmouth, Team 4-5, Vijaybhaskar Spring 2015 UMass Dartmouth, Team 4-5, Vijaybhaskar Spring 2015 회원
UMASSD-VIJAYBHASKAR-S15S4G5
3 회원들
안내서 10개 작성하였습니다
댓글 한 개
omg thank you so much 😭😭😭 I have this old camera and it has some water drop in the plastic cover… I thought it was from the inside but it actually just fine😭 if I don't found out about this web I may lost some money to fix it at the store…
Nui Bờ - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 16
전체 시간: 263
