주요 콘텐츠로 건너뛰기
Sony Cybershot DSC-T5 SD Card Replacement
필요한 것
  1. Sony Cybershot DSC-T5 SD Card Replacement, SD Card: 1 단계, 이미지 1/2 Sony Cybershot DSC-T5 SD Card Replacement, SD Card: 1 단계, 이미지 2/2
    • Hold the camera so that the right side of the camera with the panel labeled "Open" is facing up (image 1)
    • Push the panel in the direction to indicated (image 2)
  2. Sony Cybershot DSC-T5 SD Card Replacement: 2 단계, 이미지 1/3 Sony Cybershot DSC-T5 SD Card Replacement: 2 단계, 이미지 2/3 Sony Cybershot DSC-T5 SD Card Replacement: 2 단계, 이미지 3/3
    • The smaller chip near the slider of the camera is the SD card (image 1)
    • Push down on the SD card to pop it out, simply push the SD card back into the slot to re-insert it (image 2)
결론
Jason Vaccaro
회원 가입일: 03/24/15
26 평판
안내서 2개 작성하였습니다
UMass Dartmouth, Team 4-5, Vijaybhaskar Spring 2015 UMass Dartmouth, Team 4-5, Vijaybhaskar Spring 2015 회원
UMASSD-VIJAYBHASKAR-S15S4G5
3 회원들
안내서 10개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 16
30일 전: 37
전체 시간: 745
