주요 콘텐츠로 건너뛰기
Sony Cybershot DSC-T5 Sliding Lens Cover Replacement
필요한 것
  1. Sony Cybershot DSC-T5 Sliding Lens Cover Replacement, Sliding Lens Cover: 1 단계, 이미지 1/3 Sony Cybershot DSC-T5 Sliding Lens Cover Replacement, Sliding Lens Cover: 1 단계, 이미지 2/3 Sony Cybershot DSC-T5 Sliding Lens Cover Replacement, Sliding Lens Cover: 1 단계, 이미지 3/3
    • Remove all screws from the camera.
  2. Sony Cybershot DSC-T5 Sliding Lens Cover Replacement: 2 단계, 이미지 1/3 Sony Cybershot DSC-T5 Sliding Lens Cover Replacement: 2 단계, 이미지 2/3 Sony Cybershot DSC-T5 Sliding Lens Cover Replacement: 2 단계, 이미지 3/3
    • Remove the screw inside the red circles.
    • Remove the front lens cover.
    • From left to right: control panel, camera, front lens cover. The front lens cover is what we will continue to work with.
  3. Sony Cybershot DSC-T5 Sliding Lens Cover Replacement: 3 단계, 이미지 1/2 Sony Cybershot DSC-T5 Sliding Lens Cover Replacement: 3 단계, 이미지 2/2
    • Remove the blue tape. Tweezers or something similar will be required.
  4. Sony Cybershot DSC-T5 Sliding Lens Cover Replacement: 4 단계, 이미지 1/3 Sony Cybershot DSC-T5 Sliding Lens Cover Replacement: 4 단계, 이미지 2/3 Sony Cybershot DSC-T5 Sliding Lens Cover Replacement: 4 단계, 이미지 3/3
    • Remove the screws.
    • Remove lens cover from the front panel.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
John Aust
회원 가입일: 03/24/15
53 평판
안내서 2개 작성하였습니다
UMass Dartmouth, Team 4-5, Vijaybhaskar Spring 2015 UMass Dartmouth, Team 4-5, Vijaybhaskar Spring 2015 회원
UMASSD-VIJAYBHASKAR-S15S4G5
3 회원들
안내서 10개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 4
30일 전: 10
전체 시간: 462
