주요 콘텐츠로 건너뛰기
Sony Cybershot DSC-W80 LCD Screen Replacement
필요한 것
  1. Sony Cybershot DSC-W80 LCD Screen Replacement, Battery: 1 단계, 이미지 1/2 Sony Cybershot DSC-W80 LCD Screen Replacement, Battery: 1 단계, 이미지 2/2
    • Open the battery cover by sliding it towards you.
  2. Sony Cybershot DSC-W80 LCD Screen Replacement: 2 단계, 이미지 1/1
    • Push the purple latch with your thumb to unlock the battery.
    • Pull the battery out.
  3. Sony Cybershot DSC-W80 LCD Screen Replacement, Front/Back Panels: 3 단계, 이미지 1/3 Sony Cybershot DSC-W80 LCD Screen Replacement, Front/Back Panels: 3 단계, 이미지 2/3 Sony Cybershot DSC-W80 LCD Screen Replacement, Front/Back Panels: 3 단계, 이미지 3/3
    • Remove the eight Phillips #000 screws.
  4. Sony Cybershot DSC-W80 LCD Screen Replacement: 4 단계, 이미지 1/1
    • Remove the single Phillips #000 screw found next to the battery latch.
  5. Sony Cybershot DSC-W80 LCD Screen Replacement: 5 단계, 이미지 1/2 Sony Cybershot DSC-W80 LCD Screen Replacement: 5 단계, 이미지 2/2
    • Remove the middle panel on the side of the device.
    • Slowly pry the camera apart at its seem.
  6. Sony Cybershot DSC-W80 LCD Screen Replacement, LCD Screen: 6 단계, 이미지 1/3 Sony Cybershot DSC-W80 LCD Screen Replacement, LCD Screen: 6 단계, 이미지 2/3 Sony Cybershot DSC-W80 LCD Screen Replacement, LCD Screen: 6 단계, 이미지 3/3
    • Lift the power button board up off of the daughterboard.
  7. Sony Cybershot DSC-W80 LCD Screen Replacement: 7 단계, 이미지 1/1
    • Remove the single Phillips #000 screw.
    • Use your hands to remove the blue daughterboard.
  8. Sony Cybershot DSC-W80 LCD Screen Replacement: 8 단계, 이미지 1/2 Sony Cybershot DSC-W80 LCD Screen Replacement: 8 단계, 이미지 2/2
    • Flip the camera around.
    • Remove the black and orange ribbon cables.
결론
Alfred Bee
회원 가입일: 02/11/18
532 평판
안내서 2개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 5
30일 전: 18
전체 시간: 541
