주요 콘텐츠로 건너뛰기
Sony Cybershot DSC-W80 Lens Replacement
필요한 것
  1. Sony Cybershot DSC-W80 Lens Replacement, Battery: 1 단계, 이미지 1/2 Sony Cybershot DSC-W80 Lens Replacement, Battery: 1 단계, 이미지 2/2
    • Open the battery cover by sliding it towards you.
  2. Sony Cybershot DSC-W80 Lens Replacement: 2 단계, 이미지 1/1
    • Push the purple latch with your thumb to unlock the battery.
    • Pull the battery out.
  3. Sony Cybershot DSC-W80 Lens Replacement, Front/Back Panels: 3 단계, 이미지 1/3 Sony Cybershot DSC-W80 Lens Replacement, Front/Back Panels: 3 단계, 이미지 2/3 Sony Cybershot DSC-W80 Lens Replacement, Front/Back Panels: 3 단계, 이미지 3/3
    • Remove the eight Phillips #000 screws.
  4. Sony Cybershot DSC-W80 Lens Replacement: 4 단계, 이미지 1/1
    • Remove the single Phillips #000 screw found next to the battery latch.
  5. Sony Cybershot DSC-W80 Lens Replacement: 5 단계, 이미지 1/2 Sony Cybershot DSC-W80 Lens Replacement: 5 단계, 이미지 2/2
    • Remove the middle panel on the side of the device.
    • Slowly pry the camera apart at its seem.
  6. Sony Cybershot DSC-W80 Lens Replacement, Lens: 6 단계, 이미지 1/3 Sony Cybershot DSC-W80 Lens Replacement, Lens: 6 단계, 이미지 2/3 Sony Cybershot DSC-W80 Lens Replacement, Lens: 6 단계, 이미지 3/3
    • Disconnect all ribbon cables by using the flat end of a spudger to lift up the black tabs on the ZIF connectors.
    • Once disconnected, use your fingers to lift lens out of the frame.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Kierra Taylor
회원 가입일: 02/21/18
97 평판
안내서 1개 작성함
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 16
30일 전: 31
전체 시간: 616
