주요 콘텐츠로 건너뛰기
Sony Cybershot DSC-W830 Motherboard Replacement
필요한 것
  1. Sony Cybershot DSC-W830 Motherboard Replacement, Battery: 1 단계, 이미지 2개 중 1개 Sony Cybershot DSC-W830 Motherboard Replacement, Battery: 1 단계, 이미지 2개 중 2개
    • Open the battery cover by sliding it towards you.
  2. Sony Cybershot DSC-W830 Motherboard Replacement: 2 단계, 이미지 1개 중 1개
    • Push the purple latch with your thumb to unlock the battery.
    • Pull the battery out.
  3. Sony Cybershot DSC-W830 Motherboard Replacement, Front/Back Panels: 3 단계, 이미지 3개 중 1개 Sony Cybershot DSC-W830 Motherboard Replacement, Front/Back Panels: 3 단계, 이미지 3개 중 2개 Sony Cybershot DSC-W830 Motherboard Replacement, Front/Back Panels: 3 단계, 이미지 3개 중 3개
    • Remove the eight Phillips #000 screws.
  4. Sony Cybershot DSC-W830 Motherboard Replacement: 4 단계, 이미지 1개 중 1개
    • Remove the single Phillips #000 screw found next to the battery latch.
  5. Sony Cybershot DSC-W830 Motherboard Replacement: 5 단계, 이미지 2개 중 1개 Sony Cybershot DSC-W830 Motherboard Replacement: 5 단계, 이미지 2개 중 2개
    • Remove the middle panel on the side of the device.
    • Slowly pry the camera apart at its seem.
  6. Sony Cybershot DSC-W830 Motherboard Replacement, Lens: 6 단계, 이미지 3개 중 1개 Sony Cybershot DSC-W830 Motherboard Replacement, Lens: 6 단계, 이미지 3개 중 2개 Sony Cybershot DSC-W830 Motherboard Replacement, Lens: 6 단계, 이미지 3개 중 3개
    • Disconnect all ribbon cables by using the flat end of a spudger to lift up the black tabs on the ZIF connectors.
    • Once disconnected, use your fingers to lift lens out of the frame.
  7. Sony Cybershot DSC-W830 Motherboard Replacement, LCD Screen: 7 단계, 이미지 3개 중 1개 Sony Cybershot DSC-W830 Motherboard Replacement, LCD Screen: 7 단계, 이미지 3개 중 2개 Sony Cybershot DSC-W830 Motherboard Replacement, LCD Screen: 7 단계, 이미지 3개 중 3개
    • Lift the power button board up off of the daughterboard.
  8. Sony Cybershot DSC-W830 Motherboard Replacement: 8 단계, 이미지 1개 중 1개
    • Remove the single Phillips #000 screw.
    • Use your hands to remove the blue daughterboard.
  9. Sony Cybershot DSC-W830 Motherboard Replacement: 9 단계, 이미지 2개 중 1개 Sony Cybershot DSC-W830 Motherboard Replacement: 9 단계, 이미지 2개 중 2개
    • Flip the camera around.
    • Remove the black and orange ribbon cables.
  10. Sony Cybershot DSC-W830 Motherboard Replacement, Motherboard: 10 단계, 이미지 1개 중 1개
    • Remove the two remaining ribbon cables.
    • Pull the motherboard from the camera.
결론
작성자
2다른 기여자 명과 함께
Saiman Sigdel
회원 가입일: 02/21/18
167 평판
안내서 2개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 8
지난 30일: 17
전체 시간: 876
