주요 콘텐츠로 건너뛰기
Sony DCR-DVD 108 LCD Screen Replacement
필요한 것
  1. Sony DCR-DVD 108 LCD Screen Replacement, LCD Screen: 1 단계, 이미지 1/1
    • Remove the front facing screw adjacent to the LCD screen using a J1 Phillips screwdriver. The screw is 2.8 mm in length.
  2. Sony DCR-DVD 108 LCD Screen Replacement: 2 단계, 이미지 1/1
    • Rotate the camera screen until the screw on the bottom is clearly visible, then unscrew with a Phillips #1 screwdriver. This screw is 2.8mm in length.
  3. Sony DCR-DVD 108 LCD Screen Replacement: 3 단계, 이미지 1/1
    • Rotate camera again to find #1 Phillips head screw, the screw length is about 2.8 mm long. A J1 screwdriver is advised.
  4. Sony DCR-DVD 108 LCD Screen Replacement: 4 단계, 이미지 1/1
    이 단계에 사용된 도구:
    구매
    • Slowly pry apart the covers using a plastic spudger.
    • Be sure to disconnect the ZIF connector holding the ribbon cable in place. To do this, use a spudger to flip the black tab up, and pull the cable out with tweezers.
    • This photo shows a torn ribbon cable. Be sure to disconnect the ribbon cable before fully removing the LCD cover, to avoid damage to the device.
결론
Elijah DeWolf
회원 가입일: 02/09/16
577 평판
안내서 5개 작성하였습니다
USF Tampa, Team 7-6, Cheng Spring 2016 USF Tampa, Team 7-6, Cheng Spring 2016 회원
USFT-CHENG-S16S7G6
3 회원들
안내서 10개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 9
30일 전: 14
전체 시간: 649
