주요 콘텐츠로 건너뛰기
Sony DCR-DVD 108 Motherboard Replacement
필요한 것
  1. Sony DCR-DVD 108 Motherboard Replacement, Sony DCR-DVD 108 Case Disassembly: 1 단계, 이미지 1/1
    • Remove all the 4.3mm screws on the bottom using a J000 Phillips screwdriver. There should be seven screws (4 silver, 2 black).
  2. Sony DCR-DVD 108 Motherboard Replacement: 2 단계, 이미지 1/1
    • Remove the 5mm #0 Phillips screws on the underside of the LCD tuck-a-way.
  3. Sony DCR-DVD 108 Motherboard Replacement: 3 단계, 이미지 1/1
    • Remove the 2mm #0 Phillips screw behind the battery.
  4. Sony DCR-DVD 108 Motherboard Replacement: 4 단계, 이미지 1/1
    • Open the dvd cover and remove the 3 4.3mm phillips screws. Including ones in the corners that may be hidden.
  5. Sony DCR-DVD 108 Motherboard Replacement: 5 단계, 이미지 1/2 Sony DCR-DVD 108 Motherboard Replacement: 5 단계, 이미지 2/2
    • Once all the screws are removed you can safely pry open the camera case using a spudger.
  6. Sony DCR-DVD 108 Motherboard Replacement, Motherboard: 6 단계, 이미지 1/2 Sony DCR-DVD 108 Motherboard Replacement, Motherboard: 6 단계, 이미지 2/2
    이 단계에 사용된 도구:
    구매
    • Remove all ribbon connectors from the motherboard using tweezers. Simply grab each ribbon cable and pull straight out of the connector.
    • Be careful not to bend the ribbon cables.
    • There is a hidden wire on the bottom of the board that should also be removed.
  7. Sony DCR-DVD 108 Motherboard Replacement: 7 단계, 이미지 1/3 Sony DCR-DVD 108 Motherboard Replacement: 7 단계, 이미지 2/3 Sony DCR-DVD 108 Motherboard Replacement: 7 단계, 이미지 3/3
    • Remove 3 brown copper screws. Each copper screw has a #0 Phillips head and is 2.8mm in length.
  8. Sony DCR-DVD 108 Motherboard Replacement: 8 단계, 이미지 1/1
    • Lift the motherboard up from the outside edges to remove.
결론
In order to reassemble your device, follow these instructions in reverse order.
다른 한 분이 해당 안내서를 완성하였습니다.
Elijah DeWolf
회원 가입일: 02/09/16
577 평판
안내서 5개 작성하였습니다
USF Tampa, Team 7-6, Cheng Spring 2016 USF Tampa, Team 7-6, Cheng Spring 2016 회원
USFT-CHENG-S16S7G6
3 회원들
안내서 10개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 14
전체 시간: 577
