소개
The motherboard paramount for the proper function of the camera, basically acting like a "brain." This guide will serve as check for electronic connections, and a full removal procedure of this critical component.
필요한 것
Remove all the 4.3mm screws on the bottom using a J000 Phillips screwdriver. There should be seven screws (4 silver, 2 black).
거의 끝나갑니다!
In order to reassemble your device, follow these instructions in reverse order.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
