소개
How to disassemble the Sony DSC-HX50V to replace the lens.
부품
지정된 부품이 없습니다.
With needle nose pliers, gently bend back the metal tab at the bottom of the click wheel PCB so that you can release this board from the upper metal tab. Fold it away to the right and slide apart the ribbon cable from this board and place aside.
Lift the LCD display away from the camera and again carefully remove two ribbon cables and place aside.
다른 7명이 해당 안내서를 완성하였습니다.
