이 안내서에는 최근 변경 사항이 더 있습니다. 최신 비검증 버전으로 전환하십시오.
소개
Disassemble the camera to get to the lens.
필요한 것
With needle nose pliers, gently bend back the metal tab at the bottom of the click wheel PCB so that you can release this board from the upper metal tab. Fold it away to the right and slide apart the ribbon cable from this board and place aside.
Then lift the LCD display away from the camera and again carefully remove two ribbon cables (boxed in blue) and place aside.
다른 7명이 해당 안내서를 완성하였습니다.
