주요 콘텐츠로 건너뛰기
Sony DSC-RX100MA Image Sensor Replacement
필요한 것
  1. Sony DSC-RX100MA Image Sensor Replacement, Back Cover: 1 단계, 이미지 3개 중 1개 Sony DSC-RX100MA Image Sensor Replacement, Back Cover: 1 단계, 이미지 3개 중 2개 Sony DSC-RX100MA Image Sensor Replacement, Back Cover: 1 단계, 이미지 3개 중 3개
    • Remove battery by sliding the tab to open the cover
  2. Sony DSC-RX100MA Image Sensor Replacement: 2 단계, 이미지 3개 중 1개 Sony DSC-RX100MA Image Sensor Replacement: 2 단계, 이미지 3개 중 2개 Sony DSC-RX100MA Image Sensor Replacement: 2 단계, 이미지 3개 중 3개
    • Using the screwdriver, remove all screws (black 2.5mm) from outermost layer of the assembly.
    • All screws in the camera can be removed with the PH 0 driver head.
  3. Sony DSC-RX100MA Image Sensor Replacement: 3 단계, 이미지 3개 중 1개 Sony DSC-RX100MA Image Sensor Replacement: 3 단계, 이미지 3개 중 2개 Sony DSC-RX100MA Image Sensor Replacement: 3 단계, 이미지 3개 중 3개
    • Also using the screwdriver, remove screws (black 1mm) underneath articulated LCD screen.
    • Remove the marked 2.5 mm screws with the screwdriver
  4. Sony DSC-RX100MA Image Sensor Replacement: 4 단계, 이미지 2개 중 1개 Sony DSC-RX100MA Image Sensor Replacement: 4 단계, 이미지 2개 중 2개
    • Using the plastic opening tools, carefully pry off the bottom plate.
    • Do not pull too hard as you may break the plastic casing.
  5. Sony DSC-RX100MA Image Sensor Replacement: 5 단계, 이미지 3개 중 1개 Sony DSC-RX100MA Image Sensor Replacement: 5 단계, 이미지 3개 중 2개 Sony DSC-RX100MA Image Sensor Replacement: 5 단계, 이미지 3개 중 3개
    • Using the same plastic opening tools, separate the screen and back assembly from the front portion of the camera
    • Once the back assembly is slightly detached, pull the media covers for the HDMI and Multimedia ports
  6. Sony DSC-RX100MA Image Sensor Replacement: 6 단계, 이미지 2개 중 1개 Sony DSC-RX100MA Image Sensor Replacement: 6 단계, 이미지 2개 중 2개
    • Remove the back cover
  7. Sony DSC-RX100MA Image Sensor Replacement, Screen: 7 단계, 이미지 3개 중 1개 Sony DSC-RX100MA Image Sensor Replacement, Screen: 7 단계, 이미지 3개 중 2개 Sony DSC-RX100MA Image Sensor Replacement, Screen: 7 단계, 이미지 3개 중 3개
    • Move side panel to get access to screws
    • Remove two screws (black 2.5mm) with PH #0 screwdriver
  8. Sony DSC-RX100MA Image Sensor Replacement: 8 단계, 이미지 2개 중 1개 Sony DSC-RX100MA Image Sensor Replacement: 8 단계, 이미지 2개 중 2개
    • Remove back panel assembly while still keeping ribbon cable attached
    • Be very gentle and care not to tear the gold ribbon cable. This will be a common theme throughout these replacement guides.
  9. Sony DSC-RX100MA Image Sensor Replacement: 9 단계, 이미지 2개 중 1개 Sony DSC-RX100MA Image Sensor Replacement: 9 단계, 이미지 2개 중 2개
    • Carefully unplug ribbon connector to fully detach LCD screen assembly from camera
  10. Sony DSC-RX100MA Image Sensor Replacement, Image Sensor: 10 단계, 이미지 2개 중 1개 Sony DSC-RX100MA Image Sensor Replacement, Image Sensor: 10 단계, 이미지 2개 중 2개
    • Using the Philips Screwdriver, remove the screw (black 3mm) located on the copper casing.
  11. Sony DSC-RX100MA Image Sensor Replacement: 11 단계, 이미지 3개 중 1개 Sony DSC-RX100MA Image Sensor Replacement: 11 단계, 이미지 3개 중 2개 Sony DSC-RX100MA Image Sensor Replacement: 11 단계, 이미지 3개 중 3개
    • Using the plastic opening tools, carefully pry off the copper casing at the two pictured points.
    • Remove casing.
  12. Sony DSC-RX100MA Image Sensor Replacement: 12 단계, 이미지 3개 중 1개 Sony DSC-RX100MA Image Sensor Replacement: 12 단계, 이미지 3개 중 2개 Sony DSC-RX100MA Image Sensor Replacement: 12 단계, 이미지 3개 중 3개
    • Using the Philips screwdriver, remove the three (silver 3mm) screws
    • Remove the screw (silver 2mm) from the upper right hand corner
  13. Sony DSC-RX100MA Image Sensor Replacement: 13 단계, 이미지 3개 중 1개 Sony DSC-RX100MA Image Sensor Replacement: 13 단계, 이미지 3개 중 2개 Sony DSC-RX100MA Image Sensor Replacement: 13 단계, 이미지 3개 중 3개
    • Place your finger into the battery port and push up on the SD card holder to push it out of its socket.
    • Give it a little wiggle and you should feel the SD card holder come out.
  14. Sony DSC-RX100MA Image Sensor Replacement: 14 단계, 이미지 1개 중 1개
    • Now you can remove the marked gold ribbon cable from the SD card holder.
    • Utilize extreme caution while removing because the ribbon cables are extremely fragile and important to the camera.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
5다른 기여자 명과 함께
Isaiah De Leon
회원 가입일: 01/29/17
439 평판
안내서 3개를 작성함
Cal Poly, Team 21-1, Maness Winter 2017 Cal Poly, Team 21-1, Maness Winter 2017 회원
CPSU-MANESS-W17S21G1
5 회원들
안내서 10개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 4
지난 30일: 30
전체 시간: 3,697
