주요 콘텐츠로 건너뛰기
Sony DSC-RX100MA SD Motherboard Replacement
필요한 것
  1. Sony DSC-RX100MA SD Motherboard Replacement, Back Cover: 1 단계, 이미지 1/3 Sony DSC-RX100MA SD Motherboard Replacement, Back Cover: 1 단계, 이미지 2/3 Sony DSC-RX100MA SD Motherboard Replacement, Back Cover: 1 단계, 이미지 3/3
    • Remove battery by sliding the tab to open the cover
  2. Sony DSC-RX100MA SD Motherboard Replacement: 2 단계, 이미지 1/3 Sony DSC-RX100MA SD Motherboard Replacement: 2 단계, 이미지 2/3 Sony DSC-RX100MA SD Motherboard Replacement: 2 단계, 이미지 3/3
    • Using the screwdriver, remove all screws (black 2.5mm) from outermost layer of the assembly.
    • All screws in the camera can be removed with the PH 0 driver head.
  3. Sony DSC-RX100MA SD Motherboard Replacement: 3 단계, 이미지 1/3 Sony DSC-RX100MA SD Motherboard Replacement: 3 단계, 이미지 2/3 Sony DSC-RX100MA SD Motherboard Replacement: 3 단계, 이미지 3/3
    • Also using the screwdriver, remove screws (black 1mm) underneath articulated LCD screen.
    • Remove the marked 2.5 mm screws with the screwdriver
  4. Sony DSC-RX100MA SD Motherboard Replacement: 4 단계, 이미지 1/2 Sony DSC-RX100MA SD Motherboard Replacement: 4 단계, 이미지 2/2
    • Using the plastic opening tools, carefully pry off the bottom plate.
    • Do not pull too hard as you may break the plastic casing.
  5. Sony DSC-RX100MA SD Motherboard Replacement: 5 단계, 이미지 1/3 Sony DSC-RX100MA SD Motherboard Replacement: 5 단계, 이미지 2/3 Sony DSC-RX100MA SD Motherboard Replacement: 5 단계, 이미지 3/3
    • Using the same plastic opening tools, separate the screen and back assembly from the front portion of the camera
    • Once the back assembly is slightly detached, pull the media covers for the HDMI and Multimedia ports
  6. Sony DSC-RX100MA SD Motherboard Replacement: 6 단계, 이미지 1/2 Sony DSC-RX100MA SD Motherboard Replacement: 6 단계, 이미지 2/2
    • Remove the back cover
  7. Sony DSC-RX100MA SD Motherboard Replacement, Screen: 7 단계, 이미지 1/3 Sony DSC-RX100MA SD Motherboard Replacement, Screen: 7 단계, 이미지 2/3 Sony DSC-RX100MA SD Motherboard Replacement, Screen: 7 단계, 이미지 3/3
    • Move side panel to get access to screws
    • Remove two screws (black 2.5mm) with PH #0 screwdriver
  8. Sony DSC-RX100MA SD Motherboard Replacement: 8 단계, 이미지 1/2 Sony DSC-RX100MA SD Motherboard Replacement: 8 단계, 이미지 2/2
    • Remove back panel assembly while still keeping ribbon cable attached
    • Be very gentle and care not to tear the gold ribbon cable. This will be a common theme throughout these replacement guides.
  9. Sony DSC-RX100MA SD Motherboard Replacement: 9 단계, 이미지 1/2 Sony DSC-RX100MA SD Motherboard Replacement: 9 단계, 이미지 2/2
    • Carefully unplug ribbon connector to fully detach LCD screen assembly from camera
  10. Sony DSC-RX100MA SD Motherboard Replacement, SD Card Holder: 10 단계, 이미지 1/2 Sony DSC-RX100MA SD Motherboard Replacement, SD Card Holder: 10 단계, 이미지 2/2
    • Remove remaining screw which holds the copper casing in the camera
  11. Sony DSC-RX100MA SD Motherboard Replacement: 11 단계, 이미지 1/3 Sony DSC-RX100MA SD Motherboard Replacement: 11 단계, 이미지 2/3 Sony DSC-RX100MA SD Motherboard Replacement: 11 단계, 이미지 3/3
    • Using the plastic opening tools, carefully pry off the copper casing at the two pictured points.
    • Remove casing
  12. Sony DSC-RX100MA SD Motherboard Replacement: 12 단계, 이미지 1/3 Sony DSC-RX100MA SD Motherboard Replacement: 12 단계, 이미지 2/3 Sony DSC-RX100MA SD Motherboard Replacement: 12 단계, 이미지 3/3
    • Using Philips Screwdriver, remove the four screws as marked on the picture
  13. Sony DSC-RX100MA SD Motherboard Replacement: 13 단계, 이미지 1/3 Sony DSC-RX100MA SD Motherboard Replacement: 13 단계, 이미지 2/3 Sony DSC-RX100MA SD Motherboard Replacement: 13 단계, 이미지 3/3
    • Place your finger into the battery port and push up on the SD card holder to push it out of its socket.
    • Give it a little wiggle and you should feel the SD card holder come out.
  14. Sony DSC-RX100MA SD Motherboard Replacement: 14 단계, 이미지 1/1
    이 단계에 사용된 도구:
    구매
    • Carefully remove the gold ribbons from the ports of the motherboard by lifting the gray tabs and pulling away the ribbon
    • You may want to use tweezers to remove the gold ribbons as a more delicate and safe approach, but this is not required
    • Do not pull away motherboard too hard as the ribbons are very fragile
  15. Sony DSC-RX100MA SD Motherboard Replacement: 15 단계, 이미지 1/1
    • Remove the SD card holder. It should easily come out because all of the prerequisite screws were already removed.
  16. Sony DSC-RX100MA SD Motherboard Replacement, SD Motherboard: 16 단계, 이미지 1/1
    • Carefully remove the last gold ribbon by lifting the gray tab and sliding out the ribbon.
    • Be sure to use extreme caution because if this ribbon breaks, you will need to buy a new camera.
  17. Sony DSC-RX100MA SD Motherboard Replacement: 17 단계, 이미지 1/1
    • Viola! The motherboard is now removed and can be replaced with a new one.
결론
다른 3명이 해당 안내서를 완성하였습니다.
Isaiah De Leon
회원 가입일: 01/29/17
418 평판
안내서 3개 작성하였습니다
Cal Poly, Team 21-1, Maness Winter 2017 Cal Poly, Team 21-1, Maness Winter 2017 회원
CPSU-MANESS-W17S21G1
5 회원들
안내서 10개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 32
전체 시간: 2,538
