주요 콘텐츠로 건너뛰기
Sony DVP-FX730 Cover Replacement
필요한 것
  1. Sony DVP-FX730 Cover Replacement, Cover: 1 단계, 이미지 1/1
    • Remove the five exposed 7.9 mm screws using a Phillips screwdriver.
    • Punch through the warranty sticker with the spudger.
    • Remove the screw underneath with the Phillips screwdriver.
  2. Sony DVP-FX730 Cover Replacement: 2 단계, 이미지 1/1
    • Remove the rubber feet using the spudger.
    • Remove the screws that were covered by the rubber feet.
  3. Sony DVP-FX730 Cover Replacement: 3 단계, 이미지 1/1
    • Hold on to the corners of the cover and gently lift the cover.
    • The tray is still connected to the base with wires.
  4. Sony DVP-FX730 Cover Replacement: 4 단계, 이미지 1/1
    • Gently remove the wires with tweezers by pulling up on the base they are attached to.
결론
Rogelio Garcia
회원 가입일: 01/20/12
19 평판
안내서 1개 작성함
Cal Poly, Team 11-21, Maness Winter 2012 Cal Poly, Team 11-21, Maness Winter 2012 회원
CPSU-MANESS-W12S11G21
4 회원들
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 1
전체 시간: 1,451
