주요 콘텐츠로 건너뛰기
Sony DVP-FX730 Laser Replacement
필요한 것
  1. Sony DVP-FX730 Laser Replacement, Cover: 1 단계, 이미지 1/1
    • Remove the five exposed 7.9 mm screws using a Phillips screwdriver.
    • Punch through the warranty sticker with the spudger.
    • Remove the screw underneath with the Phillips screwdriver.
  2. Sony DVP-FX730 Laser Replacement: 2 단계, 이미지 1/1
    • Remove the rubber feet using the spudger.
    • Remove the screws that were covered by the rubber feet.
  3. Sony DVP-FX730 Laser Replacement: 3 단계, 이미지 1/1
    • Hold on to the corners of the cover and gently lift the cover.
    • The tray is still connected to the base with wires.
  4. Sony DVP-FX730 Laser Replacement: 4 단계, 이미지 1/1
    • Gently remove the wires with tweezers by pulling up on the base they are attached to.
  5. Sony DVP-FX730 Laser Replacement, Laser: 5 단계, 이미지 1/2 Sony DVP-FX730 Laser Replacement, Laser: 5 단계, 이미지 2/2
    • Remove the large connector.
    • Remove the small connector.
  6. Sony DVP-FX730 Laser Replacement: 6 단계, 이미지 1/1
    • Remove Philips screws with the #0 Philips Screwdriver.
  7. Sony DVP-FX730 Laser Replacement: 7 단계, 이미지 1/1
    • Lift up the black piece connected to the wires.
    • Lift gently because the ribbon cable is attached to the bottom.
  8. Sony DVP-FX730 Laser Replacement: 8 단계, 이미지 1/2 Sony DVP-FX730 Laser Replacement: 8 단계, 이미지 2/2
    • Unlock the lock clip
  9. Sony DVP-FX730 Laser Replacement: 9 단계, 이미지 1/1
    • Remove the T6 screws with the T6 screwdriver.
  10. Sony DVP-FX730 Laser Replacement: 10 단계, 이미지 1/1
    • Gently pull the rods out with tweezers.
    • Be sure the laser is out of the way so that the rods can be removed.
  11. Sony DVP-FX730 Laser Replacement: 11 단계, 이미지 1/2 Sony DVP-FX730 Laser Replacement: 11 단계, 이미지 2/2
    • Pull laser off of the rods.
    • Be careful when removing the rods because a fragile metal piece may break.
  12. Sony DVP-FX730 Laser Replacement: 12 단계, 이미지 1/1
    • The laser is now removed.
결론
Oliver Woolsoncroft
회원 가입일: 01/20/12
78 평판
안내서 2개 작성하였습니다
Cal Poly, Team 11-21, Maness Winter 2012 Cal Poly, Team 11-21, Maness Winter 2012 회원
CPSU-MANESS-W12S11G21
4 회원들
안내서 5개 작성하였습니다
댓글 한 개
where do I buy the lens?
mnmmacd - 답글
댓글 쓰기
조회 통계:
24 시간 전: 5
7일 전: 20
30일 전: 38
전체 시간: 4,725
