주요 콘텐츠로 건너뛰기
Sony DVP-FX730 Monitor Replacement
필요한 것
  1. Sony DVP-FX730 Monitor Replacement, Cover: 1 단계, 이미지 1/1
    • Remove the five exposed 7.9 mm screws using a Phillips screwdriver.
    • Punch through the warranty sticker with the spudger.
    • Remove the screw underneath with the Phillips screwdriver.
  2. Sony DVP-FX730 Monitor Replacement: 2 단계, 이미지 1/1
    • Remove the rubber feet using the spudger.
    • Remove the screws that were covered by the rubber feet.
  3. Sony DVP-FX730 Monitor Replacement: 3 단계, 이미지 1/1
    • Hold on to the corners of the cover and gently lift the cover.
    • The tray is still connected to the base with wires.
  4. Sony DVP-FX730 Monitor Replacement: 4 단계, 이미지 1/1
    • Gently remove the wires with tweezers by pulling up on the base they are attached to.
  5. Sony DVP-FX730 Monitor Replacement, Monitor: 5 단계, 이미지 1/2 Sony DVP-FX730 Monitor Replacement, Monitor: 5 단계, 이미지 2/2
    • Use your hand to remove the small back cover by gently pulling upward.
  6. Sony DVP-FX730 Monitor Replacement: 6 단계, 이미지 1/1
    • Using a screwdriver, remove the two 12 mm pan head screws.
  7. Sony DVP-FX730 Monitor Replacement: 7 단계, 이미지 1/1
    • The screen should now detach from the primary device.
    • The wires, indicated with a blue box, will still connect the screen.
  8. Sony DVP-FX730 Monitor Replacement: 8 단계, 이미지 1/2 Sony DVP-FX730 Monitor Replacement: 8 단계, 이미지 2/2
    • Remove the wires attached to the white base using tweezers to pull them up.
  9. Sony DVP-FX730 Monitor Replacement: 9 단계, 이미지 1/2 Sony DVP-FX730 Monitor Replacement: 9 단계, 이미지 2/2
    • Referring back to Step 8, do the same with the wires attached to the black base.
  10. Sony DVP-FX730 Monitor Replacement: 10 단계, 이미지 1/1
    • The screen should now be completely separated from the main device.
결론
Andrew Ward
회원 가입일: 01/20/12
93 평판
안내서 2개 작성하였습니다
Cal Poly, Team 11-21, Maness Winter 2012 Cal Poly, Team 11-21, Maness Winter 2012 회원
CPSU-MANESS-W12S11G21
4 회원들
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 3
30일 전: 5
전체 시간: 3,014
