주요 콘텐츠로 건너뛰기
Sony DVP-FX730 Screen Replacement
필요한 것
  1. Sony DVP-FX730 Screen Replacement, Monitor: 1 단계, 이미지 1/2 Sony DVP-FX730 Screen Replacement, Monitor: 1 단계, 이미지 2/2
    • Use your hand to remove the small back cover by gently pulling upward.
  2. Sony DVP-FX730 Screen Replacement: 2 단계, 이미지 1/1
    • Using a screwdriver, remove the two 12 mm pan head screws.
  3. Sony DVP-FX730 Screen Replacement: 3 단계, 이미지 1/1
    • The screen should now detach from the primary device.
    • The wires, indicated with a blue box, will still connect the screen.
  4. Sony DVP-FX730 Screen Replacement: 4 단계, 이미지 1/2 Sony DVP-FX730 Screen Replacement: 4 단계, 이미지 2/2
    이 단계에 사용된 도구:
    구매
    • Remove the wires attached to the white base using tweezers to pull them up.
  5. Sony DVP-FX730 Screen Replacement: 5 단계, 이미지 1/2 Sony DVP-FX730 Screen Replacement: 5 단계, 이미지 2/2
    • Referring back to Step 8, do the same with the wires attached to the black base.
  6. Sony DVP-FX730 Screen Replacement: 6 단계, 이미지 1/1
    • The screen should now be completely separated from the main device.
  7. Sony DVP-FX730 Screen Replacement, Screen: 7 단계, 이미지 1/1
    • Remove the four rubber feet and the screws beneath.
    • Remove the two exposed screws on the left side.
    • Pull back the cables until the screw is visible.
  8. Sony DVP-FX730 Screen Replacement: 8 단계, 이미지 1/1
    • Using the spudger, separate the top and bottom covers.
  9. Sony DVP-FX730 Screen Replacement: 9 단계, 이미지 1/1
    • Identify the gray back of the screen.
  10. Sony DVP-FX730 Screen Replacement: 10 단계, 이미지 1/1
    • Remove the screws.
  11. Sony DVP-FX730 Screen Replacement: 11 단계, 이미지 1/1
    • Remove the metal plates.
  12. Sony DVP-FX730 Screen Replacement: 12 단계, 이미지 1/2 Sony DVP-FX730 Screen Replacement: 12 단계, 이미지 2/2
    이 단계에 사용된 도구:
    구매
    • Using spudger, push the lock clips to unlock the ribbon cable.
    • Using tweezers, pull the connector loose.
  13. Sony DVP-FX730 Screen Replacement: 13 단계, 이미지 1/2 Sony DVP-FX730 Screen Replacement: 13 단계, 이미지 2/2
    • Place your hand on the front of the screen and push upwards.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Oliver Woolsoncroft
회원 가입일: 01/20/12
78 평판
안내서 2개 작성하였습니다
Cal Poly, Team 11-21, Maness Winter 2012 Cal Poly, Team 11-21, Maness Winter 2012 회원
CPSU-MANESS-W12S11G21
4 회원들
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 7
30일 전: 27
전체 시간: 2,735
