주요 콘텐츠로 건너뛰기
Sony DVP-NS325 Motherboard Replacement
필요한 것
  1. Sony DVP-NS325 Motherboard Replacement, Outer Case: 1 단계, 이미지 1/3 Sony DVP-NS325 Motherboard Replacement, Outer Case: 1 단계, 이미지 2/3 Sony DVP-NS325 Motherboard Replacement, Outer Case: 1 단계, 이미지 3/3
    • Use a Phillips screwdriver to unscrew the five screws.
  2. Sony DVP-NS325 Motherboard Replacement: 2 단계, 이미지 1/3 Sony DVP-NS325 Motherboard Replacement: 2 단계, 이미지 2/3 Sony DVP-NS325 Motherboard Replacement: 2 단계, 이미지 3/3
    • Use the Philips screwdriver to remove the screws located on the sides and the back.
    • Not shown are the right side screw and the middle screw.
  3. Sony DVP-NS325 Motherboard Replacement: 3 단계, 이미지 1/1
    • Use a spudger to separate the case from the chassis.
    • Remove the case.
  4. Sony DVP-NS325 Motherboard Replacement, Motherboard: 4 단계, 이미지 1/3 Sony DVP-NS325 Motherboard Replacement, Motherboard: 4 단계, 이미지 2/3 Sony DVP-NS325 Motherboard Replacement, Motherboard: 4 단계, 이미지 3/3
    • Remove all cables that are connected to the motherboard by pulling upwards from the motherboard.
    • Grip as close to the connectors as possible. Avoid pulling on the wires/ribbon cables.
  5. Sony DVP-NS325 Motherboard Replacement: 5 단계, 이미지 1/1
    • Use a Phillips screwdriver to remove all screws located in the 4 corners of the motherboard.
  6. Sony DVP-NS325 Motherboard Replacement: 6 단계, 이미지 1/1
    • Pull the motherboard up and out of the device.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
madison mathis
회원 가입일: 09/15/23
357 평판
안내서 3개 작성하였습니다
University of North Texas, Team 6-3, Kilpatrick Fall 2023 University of North Texas, Team 6-3, Kilpatrick Fall 2023 회원
UNT-KILPATRICK-F23S6G3
5 회원들
안내서 6개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 7
전체 시간: 78
