주요 콘텐츠로 건너뛰기
Sony DVP-NS325 Optical Drive Replacement
필요한 것
  1. Sony DVP-NS325 Optical Drive Replacement, Outer Case: 1 단계, 이미지 1/3 Sony DVP-NS325 Optical Drive Replacement, Outer Case: 1 단계, 이미지 2/3 Sony DVP-NS325 Optical Drive Replacement, Outer Case: 1 단계, 이미지 3/3
    • Use a Phillips screwdriver to unscrew the five screws.
  2. Sony DVP-NS325 Optical Drive Replacement: 2 단계, 이미지 1/3 Sony DVP-NS325 Optical Drive Replacement: 2 단계, 이미지 2/3 Sony DVP-NS325 Optical Drive Replacement: 2 단계, 이미지 3/3
    • Use the Philips screwdriver to remove the screws located on the sides and the back.
    • Not shown are the right side screw and the middle screw.
  3. Sony DVP-NS325 Optical Drive Replacement: 3 단계, 이미지 1/1
    • Use a spudger to separate the case from the chassis.
    • Remove the case.
  4. Sony DVP-NS325 Optical Drive Replacement, Optical Drive: 4 단계, 이미지 1/3 Sony DVP-NS325 Optical Drive Replacement, Optical Drive: 4 단계, 이미지 2/3 Sony DVP-NS325 Optical Drive Replacement, Optical Drive: 4 단계, 이미지 3/3
    • The Location of the three screws holding the CD reader in place.
  5. Sony DVP-NS325 Optical Drive Replacement: 5 단계, 이미지 1/1
    • Use a Phillips screwdriver to remove all three screws holding the CD reader in position.
    • Two screws not shown.
  6. Sony DVP-NS325 Optical Drive Replacement: 6 단계, 이미지 1/2 Sony DVP-NS325 Optical Drive Replacement: 6 단계, 이미지 2/2
    • Disconnect all of the optical drive motherboard connections.
  7. Sony DVP-NS325 Optical Drive Replacement: 7 단계, 이미지 1/3 Sony DVP-NS325 Optical Drive Replacement: 7 단계, 이미지 2/3 Sony DVP-NS325 Optical Drive Replacement: 7 단계, 이미지 3/3
    • Lift the four retention clips holding the face of the DVD player in place.
    • Two clips are not shown, left and bottom right side clips.
  8. Sony DVP-NS325 Optical Drive Replacement: 8 단계, 이미지 1/1
    • Remove the front face of the DVD player by pulling it away from the device.
  9. Sony DVP-NS325 Optical Drive Replacement: 9 단계, 이미지 1/1
    • Remove the optical drive.
결론
isaiah davila
회원 가입일: 09/13/23
469 평판
안내서 4개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 6
전체 시간: 48
