주요 콘텐츠로 건너뛰기
Sony DVP-NS325 Power Supply Board Replacement
필요한 것
  1. Sony DVP-NS325 Power Supply Board Replacement, Outer Case: 1 단계, 이미지 1/3 Sony DVP-NS325 Power Supply Board Replacement, Outer Case: 1 단계, 이미지 2/3 Sony DVP-NS325 Power Supply Board Replacement, Outer Case: 1 단계, 이미지 3/3
    • Use a Phillips screwdriver to unscrew the five screws.
  2. Sony DVP-NS325 Power Supply Board Replacement: 2 단계, 이미지 1/3 Sony DVP-NS325 Power Supply Board Replacement: 2 단계, 이미지 2/3 Sony DVP-NS325 Power Supply Board Replacement: 2 단계, 이미지 3/3
    • Use the Philips screwdriver to remove the screws located on the sides and the back.
    • Not shown are the right side screw and the middle screw.
  3. Sony DVP-NS325 Power Supply Board Replacement: 3 단계, 이미지 1/1
    • Use a spudger to separate the case from the chassis.
    • Remove the case.
  4. Sony DVP-NS325 Power Supply Board Replacement, Power Cable: 4 단계, 이미지 1/2 Sony DVP-NS325 Power Supply Board Replacement, Power Cable: 4 단계, 이미지 2/2
    • Unscrew all screws using a Phillips screwdriver removing the outer case to access the power cable.
  5. Sony DVP-NS325 Power Supply Board Replacement: 5 단계, 이미지 1/2 Sony DVP-NS325 Power Supply Board Replacement: 5 단계, 이미지 2/2
    • Using a finger, press down on the clip to remove the connector for the cable.
  6. Sony DVP-NS325 Power Supply Board Replacement: 6 단계, 이미지 1/1
    • Using two fingers, press in both the top and bottom clips to release the holder for the power cable to remove the cable completely.
  7. Sony DVP-NS325 Power Supply Board Replacement: 7 단계, 이미지 1/1
    • Pull the cable out of the case to fully replace the cable.
  8. Sony DVP-NS325 Power Supply Board Replacement, Power Supply Board: 8 단계, 이미지 1/2 Sony DVP-NS325 Power Supply Board Replacement, Power Supply Board: 8 단계, 이미지 2/2
    • Remove the wire connected to the motherboard by pulling the wire upwards.
    • Move the black holder piece out of the way in order to fully remove the wire from the area.
  9. Sony DVP-NS325 Power Supply Board Replacement: 9 단계, 이미지 1/1
    • Using a Phillips screwdriver, remove the four screws holding the motherboard in place.
    • There are three screws not shown all located on the corners of the motherboard.
  10. Sony DVP-NS325 Power Supply Board Replacement: 10 단계, 이미지 1/1
    • Remove the power supply board.
결론
isaiah davila
회원 가입일: 09/13/23
469 평판
안내서 4개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 11
전체 시간: 73
