주요 콘텐츠로 건너뛰기
Sony DVP-SR200P Button Circuit Board Replacement
필요한 것
  1. Sony DVP-SR200P Button Circuit Board Replacement, Top Cover: 1 단계, 이미지 1/2 Sony DVP-SR200P Button Circuit Board Replacement, Top Cover: 1 단계, 이미지 2/2
    • Remove the five #1 Phillips screws (black, 3/16") attaching the cover to the DVD player.
    • One 3/16" screw on the right side of the DVD player.
    • One 3/16" screw on the left side of the DVD player (directly opposite of other screw).
    • Three 3/16" screws on the back of the DVD player.
  2. Sony DVP-SR200P Button Circuit Board Replacement: 2 단계, 이미지 1/2 Sony DVP-SR200P Button Circuit Board Replacement: 2 단계, 이미지 2/2
    • Slide the cover away from the front of the DVD player until it is off.
  3. Sony DVP-SR200P Button Circuit Board Replacement, Processing Board: 3 단계, 이미지 1/1
    • Remove the blue tape from the processing board by gently pulling upward.
  4. Sony DVP-SR200P Button Circuit Board Replacement: 4 단계, 이미지 1/2 Sony DVP-SR200P Button Circuit Board Replacement: 4 단계, 이미지 2/2
    이 단계에 사용된 도구:
    구매
    • Use the tweezers to remove the four sets of wires connected to the processing board. Start with the cord located in front of the row of three cords.
    • The wires may be difficult to remove. Wiggling them while lifting them up may help remove them.
  5. Sony DVP-SR200P Button Circuit Board Replacement: 5 단계, 이미지 1/1
    • Handle the processing board with care. It is fragile.
    • Unscrew the two #1 Phillips screws (silver, 3/16") located on the two edge corners of the processing board.
  6. Sony DVP-SR200P Button Circuit Board Replacement: 6 단계, 이미지 1/1
    • Orient the DVD player so that you are facing the video and audio jacks.
    • Unscrew the two #1 Phillips screws (silver, 3/16") located on the outside of the DVD player
    • The processing board is now free to be removed and replaced.
  7. Sony DVP-SR200P Button Circuit Board Replacement, DVD Drive: 7 단계, 이미지 1/1
    • Orient the DVD player so the front of the DVD player is opposite of you.
    • Remove the two #1 Phillips screws (silver, 3/16") that attach the DVD drive to the bottom of the DVD player.
  8. Sony DVP-SR200P Button Circuit Board Replacement: 8 단계, 이미지 1/1
    • Remove the DVD drive by pulling it backward and upward while ensuring that it is free of any braces.
  9. Sony DVP-SR200P Button Circuit Board Replacement, Button Circuit Board: 9 단계, 이미지 1/3 Sony DVP-SR200P Button Circuit Board Replacement, Button Circuit Board: 9 단계, 이미지 2/3 Sony DVP-SR200P Button Circuit Board Replacement, Button Circuit Board: 9 단계, 이미지 3/3
    • Orient the DVD player so the button circuit board is facing you.
    • Remove the four #1 Phillips screws (silver, 3/16") from the button circuit board.
    • Three 3/16" screws from the longer button circuit board.
    • One 3/16" screw from the smaller button circuit board.
  10. Sony DVP-SR200P Button Circuit Board Replacement: 10 단계, 이미지 1/3 Sony DVP-SR200P Button Circuit Board Replacement: 10 단계, 이미지 2/3 Sony DVP-SR200P Button Circuit Board Replacement: 10 단계, 이미지 3/3
    • Hold down the copper brace that is near the far right screw hole of the long circuit board.
    • Lift the longer button circuit board over the copper brace and out of its position.
  11. Sony DVP-SR200P Button Circuit Board Replacement: 11 단계, 이미지 1/3 Sony DVP-SR200P Button Circuit Board Replacement: 11 단계, 이미지 2/3 Sony DVP-SR200P Button Circuit Board Replacement: 11 단계, 이미지 3/3
    • Push back the black, plastic clip near the left center of the shorter button circuit board.
    • Pull the shorter button circuit board out of its position.
  12. Sony DVP-SR200P Button Circuit Board Replacement: 12 단계, 이미지 1/2 Sony DVP-SR200P Button Circuit Board Replacement: 12 단계, 이미지 2/2
    • Wiggle the white cord connecting the two boards out from under the plastic pieces securing the cord.
    • Lift the button circuit board out of the DVD player.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Jeffrey Powell
회원 가입일: 01/11/13
157 평판
안내서 1개 작성함
Cal Poly, Team 5-17, Forte Winter 2013 Cal Poly, Team 5-17, Forte Winter 2013 회원
CPSU-FORTE-W13S5G17
5 회원들
안내서 6개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 3
30일 전: 11
전체 시간: 2,324
