주요 콘텐츠로 건너뛰기
Sony DVP-SR200P DVD Reader Replacement
필요한 것
  1. Sony DVP-SR200P DVD Reader Replacement, Top Cover: 1 단계, 이미지 1/2 Sony DVP-SR200P DVD Reader Replacement, Top Cover: 1 단계, 이미지 2/2
    • Remove the five #1 Phillips screws (black, 3/16") attaching the cover to the DVD player.
    • One 3/16" screw on the right side of the DVD player.
    • One 3/16" screw on the left side of the DVD player (directly opposite of other screw).
    • Three 3/16" screws on the back of the DVD player.
  2. Sony DVP-SR200P DVD Reader Replacement: 2 단계, 이미지 1/2 Sony DVP-SR200P DVD Reader Replacement: 2 단계, 이미지 2/2
    • Slide the cover away from the front of the DVD player until it is off.
  3. Sony DVP-SR200P DVD Reader Replacement, Processing Board: 3 단계, 이미지 1/1
    • Remove the blue tape from the processing board by gently pulling upward.
  4. Sony DVP-SR200P DVD Reader Replacement: 4 단계, 이미지 1/2 Sony DVP-SR200P DVD Reader Replacement: 4 단계, 이미지 2/2
    이 단계에 사용된 도구:
    구매
    • Use the tweezers to remove the four sets of wires connected to the processing board. Start with the cord located in front of the row of three cords.
    • The wires may be difficult to remove. Wiggling them while lifting them up may help remove them.
  5. Sony DVP-SR200P DVD Reader Replacement: 5 단계, 이미지 1/1
    • Handle the processing board with care. It is fragile.
    • Unscrew the two #1 Phillips screws (silver, 3/16") located on the two edge corners of the processing board.
  6. Sony DVP-SR200P DVD Reader Replacement: 6 단계, 이미지 1/1
    • Orient the DVD player so that you are facing the video and audio jacks.
    • Unscrew the two #1 Phillips screws (silver, 3/16") located on the outside of the DVD player
    • The processing board is now free to be removed and replaced.
  7. Sony DVP-SR200P DVD Reader Replacement, DVD Drive: 7 단계, 이미지 1/1
    • Orient the DVD player so the front of the DVD player is opposite of you.
    • Remove the two #1 Phillips screws (silver, 3/16") that attach the DVD drive to the bottom of the DVD player.
  8. Sony DVP-SR200P DVD Reader Replacement: 8 단계, 이미지 1/1
    • Remove the DVD drive by pulling it backward and upward while ensuring that it is free of any braces.
  9. Sony DVP-SR200P DVD Reader Replacement, DVD Reader: 9 단계, 이미지 1/3 Sony DVP-SR200P DVD Reader Replacement, DVD Reader: 9 단계, 이미지 2/3 Sony DVP-SR200P DVD Reader Replacement, DVD Reader: 9 단계, 이미지 3/3
    • Flip the DVD drive upside down, to match the orientation of the first picture.
    • Carefully remove the white ribbon cable from the brace holding it in place by sliding it out towards you.
    • Next remove the brace from the DVD drive. Carefully wiggle and pull the brace upward as the white ribbon cable slides out through the brace.
  10. Sony DVP-SR200P DVD Reader Replacement: 10 단계, 이미지 1/1
    • Remove the four silver #1 Phillips 3/16''screws to free the DVD reader from the DVD drive.
  11. Sony DVP-SR200P DVD Reader Replacement: 11 단계, 이미지 1/1
    • Remove the DVD reader from the DVD drive by pulling it upwards off of the drive.
    • The DVD reader can now be replaced.
결론
다른 3명이 해당 안내서를 완성하였습니다.
Jose Coronel
회원 가입일: 01/11/13
84 평판
안내서 1개 작성함
Cal Poly, Team 5-17, Forte Winter 2013 Cal Poly, Team 5-17, Forte Winter 2013 회원
CPSU-FORTE-W13S5G17
5 회원들
안내서 6개 작성하였습니다
댓글 한 개
Which part help to play games in dvd player
WWE Final Fighters - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 3
30일 전: 14
전체 시간: 4,861
