주요 콘텐츠로 건너뛰기
Sony Dream Machine ICF-C717PJ Battery Replacement
필요한 것
  1. Sony Dream Machine ICF-C717PJ Battery Replacement, Battery: 1 단계, 이미지 1/1
    • To start, use a small phillips screwdriver, to remove the screw located on the battery component on the back of the device.
  2. Sony Dream Machine ICF-C717PJ Battery Replacement: 2 단계, 이미지 1/2 Sony Dream Machine ICF-C717PJ Battery Replacement: 2 단계, 이미지 2/2
    • Once you have removed the screw from the battery cover, pull out the cover using your fingers.
  3. Sony Dream Machine ICF-C717PJ Battery Replacement: 3 단계, 이미지 1/1
    • Remove the remaining screws from the back of the clock.
    • Set them aside for reassembly
  4. Sony Dream Machine ICF-C717PJ Battery Replacement: 4 단계, 이미지 1/2 Sony Dream Machine ICF-C717PJ Battery Replacement: 4 단계, 이미지 2/2
    • Remove the back panel of the clock, pry open with screwdriver if necessary.
    • Ensure that the red wires connecting the back panel and the main device are not frayed or damage before proceeding to the next step.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Ainsley McCullough
회원 가입일: 06/25/18
168 평판
안내서 1개 작성함
UW Tacoma, Team S1-G3, Liner Summer 2018 UW Tacoma, Team S1-G3, Liner Summer 2018 회원
UWT-LINER-SU18S1G3
4 회원들
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 5
30일 전: 35
전체 시간: 1,892
