주요 콘텐츠로 건너뛰기
Sony DualSense Controller Front Case Replacement
필요한 것
  1. Sony DualSense Controller Front Case Replacement, Unclip the right end of the middle trim: 1 단계, 이미지 1/2 Sony DualSense Controller Front Case Replacement, Unclip the right end of the middle trim: 1 단계, 이미지 2/2
    • Disconnect and power down your controller before you begin.
    • Insert an opening pick underneath the middle trim at the bottom-right corner of the controller to release the clips securing it to the case.
  2. Sony DualSense Controller Front Case Replacement, Unclip the lower-right edge of the middle trim: 2 단계, 이미지 1/3 Sony DualSense Controller Front Case Replacement, Unclip the lower-right edge of the middle trim: 2 단계, 이미지 2/3 Sony DualSense Controller Front Case Replacement, Unclip the lower-right edge of the middle trim: 2 단계, 이미지 3/3
    • Slide the opening pick along the lower-right edge of the middle trim to release the clips securing it to the case.
  3. Sony DualSense Controller Front Case Replacement, Unclip the left end of the middle trim: 3 단계, 이미지 1/2 Sony DualSense Controller Front Case Replacement, Unclip the left end of the middle trim: 3 단계, 이미지 2/2
    • Insert an opening pick underneath the middle trim at the bottom-left corner of the controller to release the clips securing it to the case.
  4. Sony DualSense Controller Front Case Replacement, Unclip the lower-left edge of the middle trim: 4 단계, 이미지 1/3 Sony DualSense Controller Front Case Replacement, Unclip the lower-left edge of the middle trim: 4 단계, 이미지 2/3 Sony DualSense Controller Front Case Replacement, Unclip the lower-left edge of the middle trim: 4 단계, 이미지 3/3
    • Slide the opening pick along the lower-left edge of the middle trim to release the clips securing it to the case.
  5. Sony DualSense Controller Front Case Replacement, Remove the middle trim: 5 단계, 이미지 1/3 Sony DualSense Controller Front Case Replacement, Remove the middle trim: 5 단계, 이미지 2/3 Sony DualSense Controller Front Case Replacement, Remove the middle trim: 5 단계, 이미지 3/3
    • Use your fingers to lift up the bottom edge of the middle trim to release the remaining clips.
    • Lift the middle trim over the joysticks to remove it.
  6. Sony DualSense Controller Front Case Replacement, Remove the L1 button: 6 단계, 이미지 1/3 Sony DualSense Controller Front Case Replacement, Remove the L1 button: 6 단계, 이미지 2/3 Sony DualSense Controller Front Case Replacement, Remove the L1 button: 6 단계, 이미지 3/3
    • Insert the flat end of a spudger into the gap above the L1 button.
    • Cover the button with your thumb to prevent it from ejecting across the room.
    • Pry upward to remove the L1 button.
    Tried prying from the front of the buttons as pictured and my spudger broke off in the gap. A video I watched showed them being pried off from the back (between the R1/R2 and L1/L2 buttons) which seemed much easier.
    Lora Singleton - 답글
    Agree with Lora's comment above. I was able to use an old credit card to take L1/R1 out this way. I pressed down the L2/R2 button to create space to work in, then came in from between L1/L2 and R1/R2. It's easy to pop one of the outer corners first then you can work the credit card around the top and the rest falls out.
    darkstar448 - 답글
    Man, if I'd just read the thumb part...
    caldugen - 답글
  7. Sony DualSense Controller Front Case Replacement, Remove the R1 button: 7 단계, 이미지 1/3 Sony DualSense Controller Front Case Replacement, Remove the R1 button: 7 단계, 이미지 2/3 Sony DualSense Controller Front Case Replacement, Remove the R1 button: 7 단계, 이미지 3/3
    • Insert the flat end of a spudger into the gap above the R1 button.
    • Pry upward to remove the R1 button.
    to save a few bucks, the L1 and R1 buttons can be removed without the use of the spudger tool by using any thin prying tool and just pry the buttons from the bottom instead of the top
    Alan Peng - 답글
    What I didn't see addressed anywhere (here or in other similar articles) is that replacement R1 / L1 buttons can be differ enough to be un-usable depending on which model your ps5 controller is. The ones I ordered don't fit and now I can't find a way to be sure I get the right ones because few know there's even a difference.
    Walt Mather - 답글
    Did you already figured it out? The version the we need yo use?, We are in the same situation here.
    Gerald Ross Rodriguez -
    Lora Singleton - 답글
  8. Sony DualSense Controller Front Case Replacement, Remove the rear case: 8 단계, 이미지 1/2 Sony DualSense Controller Front Case Replacement, Remove the rear case: 8 단계, 이미지 2/2
    • Use a Phillips screwdriver to remove the two 6.4 mm screws securing the bottom corners of the lower case.
  9. Sony DualSense Controller Front Case Replacement: 9 단계, 이미지 1/2 Sony DualSense Controller Front Case Replacement: 9 단계, 이미지 2/2
    • Use a Phillips screwdriver to remove the two 6.4 mm screws behind the L1 and R1 buttons.
  10. Sony DualSense Controller Front Case Replacement: 10 단계, 이미지 1/3 Sony DualSense Controller Front Case Replacement: 10 단계, 이미지 2/3 Sony DualSense Controller Front Case Replacement: 10 단계, 이미지 3/3
    • Use the pointed edge of a spudger to unclip the two clips on either side of the headset jack.
    If these are similar in nature to the DS4’s clips, don’t use too much force so you don’t end up breaking them
    Strings Cat - 답글
    there is a clip that holds the rear cover in place located in R1 and L1
    Zargruzski nakamura - 답글
    Is there a clip in R1 and there's another in L1? Any way to see where exactly? The part of the back cover near L1 and R2 is that one that's not coming off. I can't seem to pull it off easily the way it looks in Step 11.
    tofu - 답글
    For those wondering where the bumper clip is located, it's ~1cm inwards from the end of the back shell where the bumpers are. Take a spudger in that spot and lift it upwards carefully, it should disconnect the clips if they aren't already
    Franz Rolfsvaag - 답글
  11. Sony DualSense Controller Front Case Replacement: 11 단계, 이미지 1/2 Sony DualSense Controller Front Case Replacement: 11 단계, 이미지 2/2
    • Remove the rear case.
    • On some revisions, the rear case is held with two more clips next to the previously removed bumpers. If the rear case doesn't open without force, check for those clips.
    There are four more clips/hooks hidden in the seams along the outer sides of the handles. If you pull open the controller as shown in this step, then you will shear off the two tiny clips which are right next to the R1 and L1 buttons.
    Therefore, you should first release those clips by prying the seams open sideways.
    I noticed this with the updated design of the controller, not sure whether the hooks are present on the first version.
    The hooks are not critical for the integrity of the controller as the two halves are held together by the screws hidden under the buttons. The damage does show that the controller has been taken apart.
    Nick - 답글
    Thought I'd clarify: The clips next to the L1 and R1 are on the outer side from the L1 and R1 buttons, I'd suggest zooming in on the picture to see them. They're quite easy to break, but also easy to remove using the plastic spudger along the seam, bending the bottom cover outwards
    Franz Rolfsvaag -
    I am still strugling to find the clips. Could someone point them out in the image with a screen shot or something like that.
    aGingerThing - 답글
    I keep getting stuck at this step too with the new DualSense CFI-ZCT1WA revision. The top and bottom shells seem like they are fused together next to L1/R1 but I can't seem to be able to find where these hidden clips are located. My controller is still in warranty so I don't want to break them in case I can't fix my issue.
    I tried this but it seems that the you need a lot of force and I ended up bending the tip of my spudger. Are you sure it's not the top cover that you need to pry away? The bottom cover has a ridge to make sure it's under the top cover so it's not easy to bend outwards.
    @samomio I think there needs to be a step added for these new clips.
    robplease - 답글
    Ok, not seeing a lot of motion on this request, so I've uploaded photos of the hooks to imgur.
    Here ya go: https://imgur.io/a/7NWmQi5
    Sean Murphy - 답글
    Life save Sean. Appreciate the image.
    Vili - 답글
    This guide really needs an update on this. I had a really hard time getting the forward clips to release even after referring to the comments above. Pretty sure I broke them in the end. No big deal but would be great if the iFixit experts could work out a good method for releasing them.
    Marcus Harvey - 답글
    I finally figure it out!!
    The hidden clip is very tricky but once you understand how it works it is easy to remove.
    Use Sean's picture: https://imgur.io/a/7NWmQi5
    What sean is showing, is actually the bottom shell of the seam.
    To disassemble
    1. Use the flat side of the spudger, pry the bottom seam OUTWARDS near the R1/L1 button hole.
    2. (most important) While prying the bottom shell seam outwards, push your thumb on the upper shell and push outward as well (you can do this by applying pressure from the removed R1/L1 button hole towards the seam. And then it will disassemble automatically
    And that's it!
    Penn - 답글
    updated instruction:
    To disassemble
    2. (most important) While prying the bottom shell seam outwards, hold your thumb on the upper shell as anchor and then use your other finger to pry the bottom edge of the controller up away from the shell. If you are doing the first step, then don't worry about breaking the clip, just force it open. And then it will disassemble automatically
    And that's it!
    Penn - 답글
    I managed to do it just by pulling harder than what I was already doing. And I don't think I broke anything. So, for me at least, the technique described in this guide worked.
    Riedweg Guillaume - 답글
  12. Sony DualSense Controller Front Case Replacement, Disconnect the battery: 12 단계, 이미지 1/2 Sony DualSense Controller Front Case Replacement, Disconnect the battery: 12 단계, 이미지 2/2
    • Use a pair of tweezers or your fingers to disconnect the battery from the motherboard.
    • Grip the connector, not the wires, when disconnecting.
    Tweezers aren't gonna grip that the way you need.
    Leif DeWolf - 답글
    For those having trouble using tweezers to pull out the connector, you can grab below the lip of the connector and use the controller as a lever to pull it up as seen here DualSense Controller v2 Battery Replacement
    This little trick helped me so much and I believe it should be shown on this guide as well.
    Ezra Worthington - 답글
    Tweezers is too weak for this. I use my finger nails after removing the battery from the slot, straighten the cable lines and slowly wiggle it out.
    Penn - 답글
  13. Sony DualSense Controller Front Case Replacement, Remove the battery: 13 단계, 이미지 1/2 Sony DualSense Controller Front Case Replacement, Remove the battery: 13 단계, 이미지 2/2
    • Lift the battery straight out of the battery bracket.
  14. Sony DualSense Controller Front Case Replacement, Remove the lower microphone: 14 단계, 이미지 1/2 Sony DualSense Controller Front Case Replacement, Remove the lower microphone: 14 단계, 이미지 2/2
    • Grab the lower microphone ribbon cable pull tab with your fingers or a pair of tweezers and disconnect it from the motherboard.
    These ribbon cables have small tabs on either side you can use to help pull out the cable. You can slightly pull up, alternating between the two sides, to slowly wiggle the connector out.
    Tran Anh Nguyen - 답글
    Might be a rookie mistake, but DO NOT REMOVE THE WHITE BRACKETS, only the ribbon! If you do, you’ll have an awful time putting it back and will most likely mess it up. Yes I did.
    Joris D - 답글
  15. Sony DualSense Controller Front Case Replacement, Remove the battery bracket: 15 단계, 이미지 1/2 Sony DualSense Controller Front Case Replacement, Remove the battery bracket: 15 단계, 이미지 2/2
    • Use a Phillips screwdriver to remove the 6.4 mm screw securing the battery bracket.
  16. Sony DualSense Controller Front Case Replacement: 16 단계, 이미지 1/2 Sony DualSense Controller Front Case Replacement: 16 단계, 이미지 2/2
    • Lift the battery bracket out of the motherboard.
    Black and red wires fit neatly under the lower left and lower right arms of the battery bracket, to avoid potential damage when reconnecting the rear case.
    Seomhnasaigh B - 답글
    This needs to be noted. Thanks!
    Nick Gatti -
  17. Sony DualSense Controller Front Case Replacement, Disconnect the right trigger assembly: 17 단계, 이미지 1/2 Sony DualSense Controller Front Case Replacement, Disconnect the right trigger assembly: 17 단계, 이미지 2/2
    • Grip the right trigger assembly ribbon cable pull tab with a pair of tweezers or your fingers and pull up to disconnect it from the motherboard.
    • Do not completely remove the ribbon cable yet.
  18. Sony DualSense Controller Front Case Replacement: 18 단계, 이미지 1/2 Sony DualSense Controller Front Case Replacement: 18 단계, 이미지 2/2
    • Grip the right trigger assembly ribbon cable pull tab with a pair of tweezers or your fingers, and pull up to disconnect it from the trigger assembly.
    • Remove the ribbon cable.
  19. Sony DualSense Controller Front Case Replacement, Disconnect the left trigger assembly: 19 단계, 이미지 1/2 Sony DualSense Controller Front Case Replacement, Disconnect the left trigger assembly: 19 단계, 이미지 2/2
    • Grip the left trigger assembly ribbon cable pull tab with a pair of tweezers or your fingers and pull up to disconnect it from the motherboard.
  20. Sony DualSense Controller Front Case Replacement: 20 단계, 이미지 1/2 Sony DualSense Controller Front Case Replacement: 20 단계, 이미지 2/2
    • Grip the left trigger assembly ribbon cable pull tab with a pair of tweezers or your fingers, and pull up to disconnect it from the trigger assembly.
  21. Sony DualSense Controller Front Case Replacement, Disconnect the upper microphone: 21 단계, 이미지 1/2 Sony DualSense Controller Front Case Replacement, Disconnect the upper microphone: 21 단계, 이미지 2/2
    • Use a pair of tweezers or your fingers to grip the upper microphone ribbon cable pull tab, and pull up to disconnect it from the motherboard.
    what is the white thing soldered to the motherboard called where the mic ribbon cable plugs and where can i find the part?
    Abhi K - 답글
    @abhik13943 did you ever find this part?
    DaMej2895 - 답글
    unfortunately, no. i'm just using my controller without a mic.
    Abhi K -
  22. Sony DualSense Controller Front Case Replacement, Disconnect the touchpad: 22 단계, 이미지 1/2 Sony DualSense Controller Front Case Replacement, Disconnect the touchpad: 22 단계, 이미지 2/2
    • Use a pair of tweezers or your fingers to grip the touchpad ribbon cable pull tab, and pull it straight out of the motherboard connector.
  23. Sony DualSense Controller Front Case Replacement, Lift out the motherboard: 23 단계, 이미지 1/3 Sony DualSense Controller Front Case Replacement, Lift out the motherboard: 23 단계, 이미지 2/3 Sony DualSense Controller Front Case Replacement, Lift out the motherboard: 23 단계, 이미지 3/3
    • Carefully guide the joysticks through the front case and lift the motherboard out.
    • Do not completely remove the motherboard. There are four soldered wires tethering the motherboard to the vibrator motors.
    Pushing on the joysticks makes this much easier.
    zidek22 - 답글
    My motherboard wouldn't just lift right out. So I noticed there's also a pair of barely visible small black clips, one on each side of the motherboard, holding it down. One is right beside the battery connector and the other's directly across on the opposite side of the motherboard right beside the ribbon cable connector.
    Jason Mulholland - 답글
    Such a good observation!
    zidek22 -
    Just push on the sticks. Pops out like a charm, zero effort.
    Italian Retro Guy - 답글
  24. Sony DualSense Controller Front Case Replacement, Remove the light guide: 24 단계, 이미지 1/2 Sony DualSense Controller Front Case Replacement, Remove the light guide: 24 단계, 이미지 2/2
    • Use a Phillips screwdriver to remove the two 8.5 mm screws securing the light guide.
    Mine didn't have this piece
    John - 답글
  25. Sony DualSense Controller Front Case Replacement: 25 단계, 이미지 1/2 Sony DualSense Controller Front Case Replacement: 25 단계, 이미지 2/2
    • Use a pair of tweezers or your fingers to remove the light guide bracket.
  26. Sony DualSense Controller Front Case Replacement: 26 단계, 이미지 1/2 Sony DualSense Controller Front Case Replacement: 26 단계, 이미지 2/2
    • Use a pair of tweezers or your fingers to remove the light guide.
    Where do i buy a new light guide?
    Jasper Nuyts - 답글
  27. Sony DualSense Controller Front Case Replacement, Remove the speaker: 27 단계, 이미지 1/3 Sony DualSense Controller Front Case Replacement, Remove the speaker: 27 단계, 이미지 2/3 Sony DualSense Controller Front Case Replacement, Remove the speaker: 27 단계, 이미지 3/3
    • Use a pair of tweezers to remove the speaker from the midframe.
    • Be sure to reinstall the speaker in the correct orientation with the foam pad on the left side and the gold contact points on the right.
    Speaker may be attached to the motherboard via the foam pad.
    Daniel Geppert - 답글
  28. Sony DualSense Controller Front Case Replacement, Remove the midframe: 28 단계, 이미지 1/2 Sony DualSense Controller Front Case Replacement, Remove the midframe: 28 단계, 이미지 2/2
    • Use a Phillips screwdriver to remove the two 6.4 mm screws securing the midframe to the front case.
  29. Sony DualSense Controller Front Case Replacement: 29 단계, 이미지 1/3 Sony DualSense Controller Front Case Replacement: 29 단계, 이미지 2/3 Sony DualSense Controller Front Case Replacement: 29 단계, 이미지 3/3
    • Carefully lift the midframe and motherboard up and out of the front case.
    • Be careful not to strain the vibrator motor wires.
    • During reassembly, feed the touchpad's ribbon cable back through its rectangular opening in the midframe.
    Feed the ribbon cable back through the rectangular slot in the midframe during reassembly.
    Seomhnasaigh B - 답글
    Thank you for catching this!
    Sam Omiotek -
  30. Sony DualSense Controller Front Case Replacement, Remove the touchpad: 30 단계, 이미지 1/2 Sony DualSense Controller Front Case Replacement, Remove the touchpad: 30 단계, 이미지 2/2
    • Use a Phillips screwdriver to remove the two 6.4 mm screws securing the touchpad bracket to the touchpad.
    On my early 2022 controller it only had one screw, the other side was a hook, i was able to separate them but pulling the touch pad up slightly away from the top of the controller and pushing towards the side the one screw was on.
    Ryan Hynes - 답글
    Question where can a buy a brand New touch pad replacement. I ripped mijn ribbon cable from the touch pad and cant seem to fix it please help
    patrick yard - 답글
  31. Sony DualSense Controller Front Case Replacement: 31 단계, 이미지 1/3 Sony DualSense Controller Front Case Replacement: 31 단계, 이미지 2/3 Sony DualSense Controller Front Case Replacement: 31 단계, 이미지 3/3
    • Lift the touchpad bracket straight up off the front case.
    • Feed the ribbon cable back through the rectangular slot in the bracket during reassembly.
  32. Sony DualSense Controller Front Case Replacement: 32 단계, 이미지 1/1
    • Lift the front case up off of the touchpad.
    Has anyone found a replacement logic board for trackpads?
    Bob - 답글
    not sure, but i’m currently trying to take the logic board off of my track pad, idk how to
    weston kijewski -
  33. Sony DualSense Controller Front Case Replacement, Remove the conductive silicone rubber: 33 단계, 이미지 1/3 Sony DualSense Controller Front Case Replacement, Remove the conductive silicone rubber: 33 단계, 이미지 2/3 Sony DualSense Controller Front Case Replacement, Remove the conductive silicone rubber: 33 단계, 이미지 3/3
    • Use a pair of tweezers or your fingers to remove the three conductive silicone rubber pads from the inside of the front case.
    • The buttons are resting loose in the front case.
  34. Sony DualSense Controller Front Case Replacement, Remove the buttons: 34 단계, 이미지 1/1
    • Hold the front case close to the surface of your table and slowly turn the front case over to let the buttons fall out.
  35. Sony DualSense Controller Front Case Replacement, Remove the touchpad bezel: 35 단계, 이미지 1/2 Sony DualSense Controller Front Case Replacement, Remove the touchpad bezel: 35 단계, 이미지 2/2
    • Use your fingers to remove the touchpad bezel from the front case.
  36. Sony DualSense Controller Front Case Replacement: 36 단계, 이미지 1/2 Sony DualSense Controller Front Case Replacement: 36 단계, 이미지 2/2
    • Use a pair of tweezers or your fingers to remove the rubber insulation pad from the front case.
  37. Sony DualSense Controller Front Case Replacement, Remove the upper microphone: 37 단계, 이미지 1/2 Sony DualSense Controller Front Case Replacement, Remove the upper microphone: 37 단계, 이미지 2/2
    • Use a pair of tweezers or your fingers to remove the upper microphone from the front case.
    • Feed the microphone ribbon cable out carefully—the pull tab may catch on the front case.
  38. Sony DualSense Controller Front Case Replacement, Remove the microphone mute button: 38 단계, 이미지 1/3 Sony DualSense Controller Front Case Replacement, Remove the microphone mute button: 38 단계, 이미지 2/3 Sony DualSense Controller Front Case Replacement, Remove the microphone mute button: 38 단계, 이미지 3/3
    • Use your fingers to lightly pinch the plastic clip securing the microphone mute button to the front case and remove it.
  39. Sony DualSense Controller Front Case Replacement: 39 단계, 이미지 1/1
    • Only the front case remains.
결론
다른 13명이 해당 안내서를 완성하였습니다.
Sam Omiotek
회원 가입일: 02/25/19
72,547 평판
안내서 288개 작성하였습니다
댓글 2개
need an update for the “a” variant (cfi-zct1w a)
this guide works for it up until a point (the touchpad), the a variant only has 1 screw instead of two and i couldn’t get the touchpad itself removed from it’s bracket (steps 30/31)
also the “a” variant is missing the light guide bracket (step 25)
name nameson - 답글
Two broken controllers became a working one. I had a small discrepancy with touchpad but figured it out. Thanks for the guide.
Dmytro Y. - 답글
댓글 쓰기
조회 통계:
24 시간 전: 10
7일 전: 107
30일 전: 571
전체 시간: 14,983
