주요 콘텐츠로 건너뛰기
Sony DualSense Controller L1 and R1 Button Replacement
필요한 것
  1. Sony DualSense Controller L1 and R1 Button Replacement, Remove the L1 button: 1 단계, 이미지 3개 중 1개 Sony DualSense Controller L1 and R1 Button Replacement, Remove the L1 button: 1 단계, 이미지 3개 중 2개 Sony DualSense Controller L1 and R1 Button Replacement, Remove the L1 button: 1 단계, 이미지 3개 중 3개
    • With one hand, grip the controller and use your thumb to hold down the left trigger.
    • With your free hand, insert the flat end of a spudger between the L1 and L2 buttons.
    • Use the spudger to gently pry the L1 button away from the controller and remove it, holding your finger over the button so it doesn't eject.
  2. Sony DualSense Controller L1 and R1 Button Replacement, Remove the R1 button: 2 단계, 이미지 3개 중 1개 Sony DualSense Controller L1 and R1 Button Replacement, Remove the R1 button: 2 단계, 이미지 3개 중 2개 Sony DualSense Controller L1 and R1 Button Replacement, Remove the R1 button: 2 단계, 이미지 3개 중 3개
    • Repeat the previous step to remove the R1 button.
결론
다른 14명이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Sam Omiotek
회원 가입일: 02/25/19
92,845 평판
안내서 290개를 작성함
3가이드 댓글
It is easier to remove L1/R1 by going from below than by from above- without any damages.
Grim Of Doom - 답글
Does the spudger dent or mark the button when doing this?
Rory Bedell - 답글
My replacement R1 button is different enough to not fit. Fins around center sleeve are wider. So there must have been a design change at some point.
Walt Mather - 답글
댓글 쓰기
조회 통계:
지난 24시간: 32
지난 7일: 289
지난 30일: 1,276
전체 시간: 43,325
