주요 콘텐츠로 건너뛰기
Sony DualSense Controller Middle Trim Replacement
필요한 것
  1. Sony DualSense Controller Middle Trim Replacement, Unclip the right end of the middle trim: 1 단계, 이미지 1/2 Sony DualSense Controller Middle Trim Replacement, Unclip the right end of the middle trim: 1 단계, 이미지 2/2
    • Disconnect and power down your controller before you begin.
    • Insert an opening pick underneath the middle trim at the bottom-right corner of the controller to release the clips securing it to the case.
  2. Sony DualSense Controller Middle Trim Replacement, Unclip the lower-right edge of the middle trim: 2 단계, 이미지 1/3 Sony DualSense Controller Middle Trim Replacement, Unclip the lower-right edge of the middle trim: 2 단계, 이미지 2/3 Sony DualSense Controller Middle Trim Replacement, Unclip the lower-right edge of the middle trim: 2 단계, 이미지 3/3
    • Slide the opening pick along the lower-right edge of the middle trim to release the clips securing it to the case.
  3. Sony DualSense Controller Middle Trim Replacement, Unclip the left end of the middle trim: 3 단계, 이미지 1/2 Sony DualSense Controller Middle Trim Replacement, Unclip the left end of the middle trim: 3 단계, 이미지 2/2
    • Insert an opening pick underneath the middle trim at the bottom-left corner of the controller to release the clips securing it to the case.
  4. Sony DualSense Controller Middle Trim Replacement, Unclip the lower-left edge of the middle trim: 4 단계, 이미지 1/3 Sony DualSense Controller Middle Trim Replacement, Unclip the lower-left edge of the middle trim: 4 단계, 이미지 2/3 Sony DualSense Controller Middle Trim Replacement, Unclip the lower-left edge of the middle trim: 4 단계, 이미지 3/3
    • Slide the opening pick along the lower-left edge of the middle trim to release the clips securing it to the case.
  5. Sony DualSense Controller Middle Trim Replacement, Remove the middle trim: 5 단계, 이미지 1/3 Sony DualSense Controller Middle Trim Replacement, Remove the middle trim: 5 단계, 이미지 2/3 Sony DualSense Controller Middle Trim Replacement, Remove the middle trim: 5 단계, 이미지 3/3
    • Use your fingers to lift up the bottom edge of the middle trim to release the remaining clips.
    • Lift the middle trim over the joysticks to remove it.
결론
다른 6명이 해당 안내서를 완성하였습니다.
Sam Omiotek
회원 가입일: 02/25/19
73,429 평판
안내서 288개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 5
7일 전: 46
30일 전: 232
전체 시간: 6,575
