주요 콘텐츠로 건너뛰기
Sony ECM-MS907 Battery Replacement
필요한 것
  1. Sony ECM-MS907 Battery Replacement, Battery: 1 단계, 이미지 1/1
    • Take off the windshield from the top of the microphone and place aside. The bottom part of the microphone is detachable. In a clockwise motion, begin unscrewing the bottom of the microphone from its base.
  2. Sony ECM-MS907 Battery Replacement: 2 단계, 이미지 1/2 Sony ECM-MS907 Battery Replacement: 2 단계, 이미지 2/2
    • Pull off the bottom base of the microphone. The microphone should now be in two pieces. After the bottom base is removed, the battery should now be visible.
  3. Sony ECM-MS907 Battery Replacement: 3 단계, 이미지 1/1
    • To remove the battery, push it upward into the aluminum spring. This will loosen and free the battery.
  4. Sony ECM-MS907 Battery Replacement: 4 단계, 이미지 1/2 Sony ECM-MS907 Battery Replacement: 4 단계, 이미지 2/2
    • Select a new, (AA) battery to insert into the microphone. Match the (+) and (-) sides of the battery to the matching symbols inside the microphone.
결론
다른 3명이 해당 안내서를 완성하였습니다.
Kefaya
회원 가입일: 01/23/14
364 평판
안내서 3개 작성하였습니다
New Mexico State, Team 1-2, Sheppard Spring 2014 New Mexico State, Team 1-2, Sheppard Spring 2014 회원
NMSU-SHEPPARD-S14S1G2
3 회원들
안내서 6개 작성하였습니다
댓글 2개
Excellent tuto : clair direct et simple
Une fois avoir changé la pile, j’ai découvert qu’il y a un mauvais contact avec le bouton de commande. Quand on le manipule, le voyant s’allume 1/4 de secondes et s’éteint. Pourriez vous ‘m’indiquer un tuto pour le démontage complet du microphone Sony.
Ou bien m’indiquer un réparateur sur Paris
Merci à Kefaya et bonne soirée
henri75012@club-internet.fr
Biezin - 답글
Remarquable tuto, illustré par de magnifiques photos, très claires. Merci beaucoup !
DENIS PERRIN - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 14
전체 시간: 4,972
