주요 콘텐츠로 건너뛰기
Sony ECM-MS907 Volume issue troubleshooting
  1. Sony ECM-MS907 Volume issue troubleshooting, Sony ECM-MS907 Volume issue troubleshooting: 1 단계, 이미지 2개 중 1개 Sony ECM-MS907 Volume issue troubleshooting, Sony ECM-MS907 Volume issue troubleshooting: 1 단계, 이미지 2개 중 2개
    • Often when using the recording range of 90 degrees, a low recording occurs. This particular setting seems tailored towards a much louder object, such as a musical instrument, etc.
    • To change this setting, change switch to the 120 degree recording range.
  2. Sony ECM-MS907 Volume issue troubleshooting: 2 단계, 이미지 1개 중 1개
    • Another problem involves the stereo jack of the microphone being inserted into the wrong output of the external device.
  3. Sony ECM-MS907 Volume issue troubleshooting: 3 단계, 이미지 2개 중 1개 Sony ECM-MS907 Volume issue troubleshooting: 3 단계, 이미지 2개 중 2개
    • In this particular external device, the Sony MiniDisc player, the microphone stereo jack can mistakenly be inserted into the laptop, or "white" input.
    • Always remember to insert stereo jack into the microplug, or "red" input.
  4. Sony ECM-MS907 Volume issue troubleshooting: 4 단계, 이미지 1개 중 1개
    • Some volume issues could be related to other external devices, such as a laptop. This particular microphone was not designed to be used with a computer.
  5. Sony ECM-MS907 Volume issue troubleshooting: 5 단계, 이미지 1개 중 1개
    • One solution is to use a device such as a USB soundcard, which can be purchased online or at most electronics stores.
    • Simply insert soundcard into a USB input in the laptop
    • Insert stereo jack of microphone into the soundcard input marked with the "microphone" symbol.
    • This may resolve laptop related problems related to low volume during recordings.
결론
작성자
7다른 기여자 명과 함께
Justin Lewis
회원 가입일: 01/23/14
242 평판
안내서 2개를 작성함
New Mexico State, Team 1-2, Sheppard Spring 2014 New Mexico State, Team 1-2, Sheppard Spring 2014 회원
NMSU-SHEPPARD-S14S1G2
3 회원들
안내서 6개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 2
지난 30일: 11
전체 시간: 1,347
