주요 콘텐츠로 건너뛰기
Sony Ericsson J22Oi Charging Port Replacement
필요한 것
  1. Sony Ericsson J22Oi Charging Port Replacement, Battery: 1 단계, 이미지 1/1
    • Before disassembling the phone, make sure the phone is powered off.
  2. Sony Ericsson J22Oi Charging Port Replacement: 2 단계, 이미지 1/1
    • Flip to the back of the phone and locate the black button on the top of the phone.
  3. Sony Ericsson J22Oi Charging Port Replacement: 3 단계, 이미지 1/1
    • Firmly hold down the black button on the top of the phone and gently snap off the back cover.
  4. Sony Ericsson J22Oi Charging Port Replacement: 4 단계, 이미지 1/1
    • Remove the battery by wedging it out from the back.
  5. Sony Ericsson J22Oi Charging Port Replacement, Keypad: 5 단계, 이미지 1/1
    • Flip to the front of the phone and apply pressure to the front frame of the phone. The frame should snap off easily.
  6. Sony Ericsson J22Oi Charging Port Replacement: 6 단계, 이미지 1/1
    • Remove the keypad by gently pulling it from the front of the phone.
  7. Sony Ericsson J22Oi Charging Port Replacement, Screen: 7 단계, 이미지 1/1
    • Locate the five screws indicated on the phone.
  8. Sony Ericsson J22Oi Charging Port Replacement: 8 단계, 이미지 1/1
    • Use a T5 Screwdriver and unscrew the five screws.
  9. Sony Ericsson J22Oi Charging Port Replacement: 9 단계, 이미지 1/1
    • Once the screws are off, there should be a plastic cover on top of your screen. Gently slide the plastic cover off.
  10. Sony Ericsson J22Oi Charging Port Replacement: 10 단계, 이미지 1/1
    • Now gently pull metal cover off.
  11. Sony Ericsson J22Oi Charging Port Replacement: 11 단계, 이미지 1/1
    • You should now see the screen on the front side of the phone. Wedge your finger to the side of the phone. Apply some force to pop out the screen.
  12. Sony Ericsson J22Oi Charging Port Replacement: 12 단계, 이미지 1/1
    • Now that screen is removed, replace the old screen with the new screen.
    • Reassemble the device by doing the steps in reverse order.
  13. Sony Ericsson J22Oi Charging Port Replacement, Charging Port: 13 단계, 이미지 1/1
    • After removing the screen, you will find the charging port located at the bottom of the phone.
  14. Sony Ericsson J22Oi Charging Port Replacement: 14 단계, 이미지 1/1
    • Gently slide off the charging port.
결론
James Au
회원 가입일: 10/06/12
10 평판
안내서 4개 작성하였습니다
Cal Poly, Team 6-36, Regan Fall 2012 Cal Poly, Team 6-36, Regan Fall 2012 회원
CPSU-REGAN-F12S6G36
3 회원들
안내서 10개 작성하였습니다
댓글 한 개
Nice information for me , I also repairing the mobile phone
Mohit - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 3
전체 시간: 1,354
