메인 콘텐츠로 스킵하기
소개
This guide will show the user how to disassemble a Sony Ericsson J22Oi with the intent of removing and replacing the charging port.
부품
지정된 부품이 없습니다.
  1. Before disassembling the phone, make sure the phone is powered off.
    • Before disassembling the phone, make sure the phone is powered off.
  2. Flip to the back of the phone and locate the black button on the top of the phone.
    • Flip to the back of the phone and locate the black button on the top of the phone.
  3. Firmly hold down the black button on the top of the phone and gently snap off the back cover.
    • Firmly hold down the black button on the top of the phone and gently snap off the back cover.
  4. Remove the battery by wedging it out from the back.
    • Remove the battery by wedging it out from the back.
  5. Flip to the front of the phone and apply pressure to the front frame of the phone.  The frame should snap off easily.
    • Flip to the front of the phone and apply pressure to the front frame of the phone. The frame should snap off easily.
  6. Remove the keypad by gently pulling it from the front of the phone.
    • Remove the keypad by gently pulling it from the front of the phone.
  7. Locate the five screws indicated on the phone.
    • Locate the five screws indicated on the phone.
  8. Use a T5 Screwdriver and unscrew the five screws.
    • Use a T5 Screwdriver and unscrew the five screws.
  9. Once the screws are off, there should be a plastic cover on top of your screen.  Gently slide the plastic cover off.
    • Once the screws are off, there should be a plastic cover on top of your screen. Gently slide the plastic cover off.
  10. Now gently pull metal cover off.
    • Now gently pull metal cover off.
  11. You should now see the screen on the front side of the phone. Wedge your finger to the side of the phone.  Apply some force to pop out the screen.
    • You should now see the screen on the front side of the phone. Wedge your finger to the side of the phone. Apply some force to pop out the screen.
  12. Now that screen is removed, replace the old screen with the new screen.
    • Now that screen is removed, replace the old screen with the new screen.
    • Reassemble the device by doing the steps in reverse order.
  13. After removing the screen, you will find the charging port located at the bottom of the phone.
    • After removing the screen, you will find the charging port located at the bottom of the phone.
  14. Gently slide off the charging port.
    • Gently slide off the charging port.
결론
James Au
회원 가입일: 2012년 10월 06일
10 평판
안내서 4개 작성하였습니다
Cal Poly, Team 6-36, Regan Fall 2012 Cal Poly, Team 6-36, Regan Fall 2012 회원
CPSU-REGAN-F12S6G36
3 회원들
안내서 10개 작성하였습니다
Nice information for me , I also repairing the mobile phone
Mohit - 답글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 1
전체 시간: 1,126
