주요 콘텐츠로 건너뛰기
Fix Your Stuff
Right to Repair
Parts & Tools
소개
You will need to obtain a T5 screwdriver in order to effectively remove the screen from the phone.
부품
지정된 부품이 없습니다.
  1. Before disassembling the phone, make sure the phone is powered off.
    • Before disassembling the phone, make sure the phone is powered off.
  2. Flip to the back of the phone and locate the black button on the top of the phone.
    • Flip to the back of the phone and locate the black button on the top of the phone.
  3. Firmly hold down the black button on the top of the phone and gently snap off the back cover.
    • Firmly hold down the black button on the top of the phone and gently snap off the back cover.
  4. Remove the battery by wedging it out from the back.
    • Remove the battery by wedging it out from the back.
  5. Locate the five screws indicated on the phone.
    • Locate the five screws indicated on the phone.
  6. Use a T5 Screwdriver and unscrew the five screws.
    • Use a T5 Screwdriver and unscrew the five screws.
  7. Once the screws are off, there should be a plastic cover on top of your screen.  Gently slide the plastic cover off.
    • Once the screws are off, there should be a plastic cover on top of your screen. Gently slide the plastic cover off.
  8. Now gently pull metal cover off.
    • Now gently pull metal cover off.
  9. You should now see the screen on the front side of the phone. Wedge your finger to the side of the phone.  Apply some force to pop out the screen.
    • You should now see the screen on the front side of the phone. Wedge your finger to the side of the phone. Apply some force to pop out the screen.
  10. Now that screen is removed, replace the old screen with the new screen.
    • Now that screen is removed, replace the old screen with the new screen.
    • Reassemble the device by doing the steps in reverse order.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
James Au
회원 가입일: 2012년 10월 06일
10 평판
안내서 4개 작성하였습니다
Cal Poly, Team 6-36, Regan Fall 2012 Cal Poly, Team 6-36, Regan Fall 2012 회원
CPSU-REGAN-F12S6G36
3 회원들
안내서 10개 작성하였습니다
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 340
