주요 콘텐츠로 건너뛰기
Sony Ericsson K750i Back Casing Replacement
필요한 것
  1. Sony Ericsson K750i Back Casing Replacement, Battery Cover: 1 단계, 이미지 1/1
    • Remove the battery cover.
    • Press down firmly with your thumb and slide the cover back.
  2. Sony Ericsson K750i Back Casing Replacement, Back Casing: 2 단계, 이미지 1/1
    • Remove two Phillips #0 screws from the battery chamber.
    • Remove two Torx T6 screws from the battery chamber.
  3. Sony Ericsson K750i Back Casing Replacement: 3 단계, 이미지 1/1
    • Gently pry off the back casing.
    • Work an opening tool around the entire seam before attempting to pull off the casing. This action will reduce the chance of cracking the casing.
  4. Sony Ericsson K750i Back Casing Replacement: 4 단계, 이미지 1/1
    • Remove the casing to expose the camera's components.
결론
Abby Evers
회원 가입일: 10/04/11
202 평판
안내서 6개 작성하였습니다
UW Stout, Team 1-6, Zhou Fall 2011 UW Stout, Team 1-6, Zhou Fall 2011 회원
UWSTOUT-ZHOU-F11S1G6
4 회원들
안내서 12개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 4
전체 시간: 3,535
