주요 콘텐츠로 건너뛰기
Sony Ericsson K750i Joystick Replacement
필요한 것
  1. Sony Ericsson K750i Joystick Replacement, Battery Cover: 1 단계, 이미지 1/1
    • Remove the battery cover.
    • Press down firmly with your thumb and slide the cover back.
  2. Sony Ericsson K750i Joystick Replacement, Back Casing: 2 단계, 이미지 1/1
    • Remove two Phillips #0 screws from the battery chamber.
    • Remove two Torx T6 screws from the battery chamber.
  3. Sony Ericsson K750i Joystick Replacement: 3 단계, 이미지 1/1
    • Gently pry off the back casing.
    • Work an opening tool around the entire seam before attempting to pull off the casing. This action will reduce the chance of cracking the casing.
  4. Sony Ericsson K750i Joystick Replacement: 4 단계, 이미지 1/1
    • Remove the casing to expose the camera's components.
  5. Sony Ericsson K750i Joystick Replacement, Keypad: 5 단계, 이미지 1/1
    • Gently pry open the front casing by working an opening tool along the entire seam.
  6. Sony Ericsson K750i Joystick Replacement: 6 단계, 이미지 1/1
    • Remove the front casing by gently lifting it from the phone.
    • Be careful not to pull off any other delicate pieces.
  7. Sony Ericsson K750i Joystick Replacement: 7 단계, 이미지 1/2 Sony Ericsson K750i Joystick Replacement: 7 단계, 이미지 2/2
    • Remove the keypad.
    • The LCD screen is very fragile. Be careful not to catch the keypad on it while removing.
  8. Sony Ericsson K750i Joystick Replacement, Joystick: 8 단계, 이미지 1/1
    • Remove the front cover and casing to expose the joystick.
  9. Sony Ericsson K750i Joystick Replacement: 9 단계, 이미지 1/1
    • Use tweezers to get a grip on the joystick.
  10. Sony Ericsson K750i Joystick Replacement: 10 단계, 이미지 1/1
    • Once you have a firm grip, carefully remove the joystick.
    • Caution: The green film surrounding the joystick is fragile. Take care not to puncture or rip it.
  11. Sony Ericsson K750i Joystick Replacement: 11 단계, 이미지 1/1
    • Using tweezers, insert the new joystick in place of the previous joystick.
결론
다른 3명이 해당 안내서를 완성하였습니다.
Abby Evers
회원 가입일: 10/04/11
202 평판
안내서 6개 작성하였습니다
UW Stout, Team 1-6, Zhou Fall 2011 UW Stout, Team 1-6, Zhou Fall 2011 회원
UWSTOUT-ZHOU-F11S1G6
4 회원들
안내서 12개 작성하였습니다
댓글 한 개
That is the joystick head and it can be removed without taking anything apart. The problem is in joystick underneath it, which is soldered and need to be replaced. I know this phone is 15 years old, I just found mine and it brought back some memories :)
Lazar Trnavac - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 9
전체 시간: 6,912
