소개
Please note: you must remove the screws from the back casing before beginning this guide.
  1. Remove 4 screws from battery chamber
    • Remove 4 screws from battery chamber
    • Red - Phillips 0 screwdriver
    • Blue - Torx 6 screwdriver
  2. Gently pry off back casing
    • Gently pry off back casing
    • Note: work shim or flathead screwdriver around entire seam before attempting to pull off casing. This will reduce the chance of cracking the casing.
  3. 맥북 배터리 수리 키트
    기본 가격은 $69.99
    Buy Now
    맥북 배터리 수리 키트
    기본 가격은 $69.99
    Buy Now
  4. Remove casing to expose camera components
    • Remove casing to expose camera components
  5. Gently pry open front casing by working a small shim or flathead screwdriver along the entire seam
    • Gently pry open front casing by working a small shim or flathead screwdriver along the entire seam
  6. Remove front casing by gently lifting it from the phone
    • Remove front casing by gently lifting it from the phone
    • Be careful not to pull off any other delicate pieces
  7. Keypad should be easy to remove Caution: LCD screen is very fragile. Be careful not to catch the keypad on it while removing.
    • Keypad should be easy to remove
    • Caution: LCD screen is very fragile. Be careful not to catch the keypad on it while removing.
결론
Abby Evers
회원 가입일: 2011년 10월 04일
196 평판
안내서 6개 작성하였습니다
UW Stout, Team 1-6, Zhou Fall 2011 UW Stout, Team 1-6, Zhou Fall 2011 회원
UWSTOUT-ZHOU-F11S1G6
4 회원들
안내서 12개 작성하였습니다
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 1
전체 시간: 3,006
