  1. Remove battery cover
    • Remove battery cover
    • Press down firmly with thumb and slide cover back
  2. Remove 4 screws from battery chamber
    • Remove 4 screws from battery chamber
    • Red - Phillips 0 screwdriver
    • Blue - Torx 6 screwdriver
  3. Gently pry off back casing
    • Gently pry off back casing
    • Note: work shim or flathead screwdriver around entire seam before attempting to pull off casing. This will reduce the chance of cracking the casing.
  4. Remove casing to expose camera components
    • Remove casing to expose camera components
  5. 아이폰 배터리 수리 키트
    Only $29.99
    Buy Now
    아이폰 배터리 수리 키트
    Only $29.99
    Buy Now
  6. Gently pry open front casing by working a small shim or flathead screwdriver along the entire seam
    • Gently pry open front casing by working a small shim or flathead screwdriver along the entire seam
  7. Remove front casing by gently lifting it from the phone
    • Remove front casing by gently lifting it from the phone
    • Be careful not to pull off any other delicate pieces
  8. Keypad should be easy to remove Caution: LCD screen is very fragile. Be careful not to catch the keypad on it while removing.
    • Keypad should be easy to remove
    • Caution: LCD screen is very fragile. Be careful not to catch the keypad on it while removing.
  9. Remove screws holding the screen in place
    • Remove screws holding the screen in place
  10. Gently lift the base of the keypad to remove it
    • Gently lift the base of the keypad to remove it
  11. Gently pull up the green film.
    • Gently pull up the green film.
    • Avoid the joystick
    • The LCD screen will be attached to this film and come off with it.
    • Caution: LCD screen is very fragile. Handle with care.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Abby Evers
회원 가입일: 2011년 10월 04일
196 평판
안내서 6개 작성하였습니다
UW Stout, Team 1-6, Zhou Fall 2011 UW Stout, Team 1-6, Zhou Fall 2011 회원
UWSTOUT-ZHOU-F11S1G6
4 회원들
안내서 12개 작성하였습니다
Works perfectly, thank you guys!
Aurelien - 답글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 2
전체 시간: 3,568
