주요 콘텐츠로 건너뛰기
Sony Ericsson K750i LCD Screen Replacement
필요한 것
  1. Sony Ericsson K750i LCD Screen Replacement, Battery Cover: 1 단계, 이미지 1/1
    • Remove the battery cover.
    • Press down firmly with your thumb and slide the cover back.
  2. Sony Ericsson K750i LCD Screen Replacement, Back Casing: 2 단계, 이미지 1/1
    • Remove two Phillips #0 screws from the battery chamber.
    • Remove two Torx T6 screws from the battery chamber.
  3. Sony Ericsson K750i LCD Screen Replacement: 3 단계, 이미지 1/1
    • Gently pry off the back casing.
    • Work an opening tool around the entire seam before attempting to pull off the casing. This action will reduce the chance of cracking the casing.
  4. Sony Ericsson K750i LCD Screen Replacement: 4 단계, 이미지 1/1
    • Remove the casing to expose the camera's components.
  5. Sony Ericsson K750i LCD Screen Replacement, Keypad: 5 단계, 이미지 1/1
    • Gently pry open the front casing by working an opening tool along the entire seam.
  6. Sony Ericsson K750i LCD Screen Replacement: 6 단계, 이미지 1/1
    • Remove the front casing by gently lifting it from the phone.
    • Be careful not to pull off any other delicate pieces.
  7. Sony Ericsson K750i LCD Screen Replacement: 7 단계, 이미지 1/2 Sony Ericsson K750i LCD Screen Replacement: 7 단계, 이미지 2/2
    • Remove the keypad.
    • The LCD screen is very fragile. Be careful not to catch the keypad on it while removing.
  8. Sony Ericsson K750i LCD Screen Replacement, LCD Screen: 8 단계, 이미지 1/1
    • Remove the screws holding the screen in place.
  9. Sony Ericsson K750i LCD Screen Replacement: 9 단계, 이미지 1/1
    • Gently lift the base of the keypad to remove it.
  10. Sony Ericsson K750i LCD Screen Replacement: 10 단계, 이미지 1/1
    • Gently pull up the green film, avoiding the joystick.
    • The LCD screen will be attached to this film and come off with it.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Abby Evers
회원 가입일: 10/04/11
202 평판
안내서 6개 작성하였습니다
UW Stout, Team 1-6, Zhou Fall 2011 UW Stout, Team 1-6, Zhou Fall 2011 회원
UWSTOUT-ZHOU-F11S1G6
4 회원들
안내서 12개 작성하였습니다
댓글 한 개
Works perfectly, thank you guys!
Aurelien - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 4
전체 시간: 4,039
