주요 콘텐츠로 건너뛰기
Sony Ericsson QuickShare T630 Screen Replacement
필요한 것
  1. Sony Ericsson QuickShare T630 Screen Replacement, Sony Ericsson QuickShare T630 Phone Enclosure: 1 단계, 이미지 1/1
    • Begin the disassembly by placing your Sony Ericsson QuickShare T630 on a flat surface.
  2. Sony Ericsson QuickShare T630 Screen Replacement: 2 단계, 이미지 1/2 Sony Ericsson QuickShare T630 Screen Replacement: 2 단계, 이미지 2/2
    • Slide the protective panel on the backside of the phone downward and remove it entirely, revealing the battery underneath.
  3. Sony Ericsson QuickShare T630 Screen Replacement: 3 단계, 이미지 1/1
    • Slide the battery upward to remove.
  4. Sony Ericsson QuickShare T630 Screen Replacement: 4 단계, 이미지 1/2 Sony Ericsson QuickShare T630 Screen Replacement: 4 단계, 이미지 2/2
    • Remove the rubber plug located near the camera by gently prying upward with your fingers.
    • Gently lift the camera shield after removal of the rubber plug.
  5. Sony Ericsson QuickShare T630 Screen Replacement: 5 단계, 이미지 1/2 Sony Ericsson QuickShare T630 Screen Replacement: 5 단계, 이미지 2/2
    • Pry the remaining panel to loosen its contact to the phone using a spudger.
    • Slide the panel upward to remove it completely.
    • These steps will require a slight appliance of force.
  6. Sony Ericsson QuickShare T630 Screen Replacement: 6 단계, 이미지 1/1
    • Slide the aerial upward to remove it.
  7. Sony Ericsson QuickShare T630 Screen Replacement: 7 단계, 이미지 1/2 Sony Ericsson QuickShare T630 Screen Replacement: 7 단계, 이미지 2/2
    • Remove the four screws located at each corner of the device.
  8. Sony Ericsson QuickShare T630 Screen Replacement: 8 단계, 이미지 1/2 Sony Ericsson QuickShare T630 Screen Replacement: 8 단계, 이미지 2/2
    • Gently lift and remove the front panel of the phone after removing the screws.
  9. Sony Ericsson QuickShare T630 Screen Replacement: 9 단계, 이미지 1/3 Sony Ericsson QuickShare T630 Screen Replacement: 9 단계, 이미지 2/3 Sony Ericsson QuickShare T630 Screen Replacement: 9 단계, 이미지 3/3
    • This step is NOT required for joystick maintenance or keypad maintenance and replacement! Continue on to step 10 if you are attempting to achieve either of these goals.
    • Slowly lift the screen to reveal the green circuit ribbon connecting the screen to the phone.
    • Gently pull the ribbon from the circuit.
    • Remove the now disconnected screen.
  10. Sony Ericsson QuickShare T630 Screen Replacement: 10 단계, 이미지 1/3 Sony Ericsson QuickShare T630 Screen Replacement: 10 단계, 이미지 2/3 Sony Ericsson QuickShare T630 Screen Replacement: 10 단계, 이미지 3/3
    • Remove the keyboard by slowly pulling it away from the circuit board.
    • There are no direct connections between the keyboard and phone.
    • These are all of the parts covered in this disassembly that make up the Sony Ericsson QuickShare T630.
  11. Sony Ericsson QuickShare T630 Screen Replacement, Sony Ericsson QuickShare T630 Screen: 11 단계, 이미지 1/3 Sony Ericsson QuickShare T630 Screen Replacement, Sony Ericsson QuickShare T630 Screen: 11 단계, 이미지 2/3 Sony Ericsson QuickShare T630 Screen Replacement, Sony Ericsson QuickShare T630 Screen: 11 단계, 이미지 3/3
    • To place a new screen, slide the green ribbon connector into the ribbon clamp that the defective screen was pulled from.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Jeremy
회원 가입일: 10/16/13
166 평판
안내서 1개 작성함
University of Maine, Team 1-1, Diaz Fall 2013 University of Maine, Team 1-1, Diaz Fall 2013 회원
UMAINE-DIAZ-F13S1G1
4 회원들
안내서 6개 작성하였습니다
댓글 한 개
Worked well until the screen replacemet - ribbon cable would not go into clamp - phone plus new screen straight in the bin - a little gutted - but hey it was an old but loved phone.
roger hiley - 답글
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 2
30일 전: 5
전체 시간: 1,322
