주요 콘텐츠로 건너뛰기
Sony Ericsson T68i Screen Replacement
필요한 것
  1. Sony Ericsson T68i Screen Replacement, Keypad: 1 단계, 이미지 1/2 Sony Ericsson T68i Screen Replacement, Keypad: 1 단계, 이미지 2/2
    • Remove the battery from the back.
  2. Sony Ericsson T68i Screen Replacement: 2 단계, 이미지 1/3 Sony Ericsson T68i Screen Replacement: 2 단계, 이미지 2/3 Sony Ericsson T68i Screen Replacement: 2 단계, 이미지 3/3
    • Pry off the plastic cover from the top with a thin plastic shim, then remove it from the two bottom clips.
    • Do not bend it too far down, or else you risk breaking the two bottom clips.
  3. Sony Ericsson T68i Screen Replacement: 3 단계, 이미지 1/3 Sony Ericsson T68i Screen Replacement: 3 단계, 이미지 2/3 Sony Ericsson T68i Screen Replacement: 3 단계, 이미지 3/3
    • Unscrew all four Torx T6 screws.
    • Keep in a safe place.
  4. Sony Ericsson T68i Screen Replacement: 4 단계, 이미지 1/3 Sony Ericsson T68i Screen Replacement: 4 단계, 이미지 2/3 Sony Ericsson T68i Screen Replacement: 4 단계, 이미지 3/3
    • After removing the screws, the two halves will separate. If not, then pry them gently apart.
  5. Sony Ericsson T68i Screen Replacement, Screen: 5 단계, 이미지 1/3 Sony Ericsson T68i Screen Replacement, Screen: 5 단계, 이미지 2/3 Sony Ericsson T68i Screen Replacement, Screen: 5 단계, 이미지 3/3
    • Remove the circuit board and screen from the device.
    • Use your T6 to remove the 4 screws.
  6. Sony Ericsson T68i Screen Replacement: 6 단계, 이미지 1/3 Sony Ericsson T68i Screen Replacement: 6 단계, 이미지 2/3 Sony Ericsson T68i Screen Replacement: 6 단계, 이미지 3/3
    • Remove the board and screen.
  7. Sony Ericsson T68i Screen Replacement: 7 단계, 이미지 1/3 Sony Ericsson T68i Screen Replacement: 7 단계, 이미지 2/3 Sony Ericsson T68i Screen Replacement: 7 단계, 이미지 3/3
    • Carefully remove the plastic clips holding the screen on the board.
결론
Tim Dascomb
회원 가입일: 04/13/10
159 평판
안내서 7개 작성하였습니다
Cal Poly, Team 26-34, Regan Spring 2010 Cal Poly, Team 26-34, Regan Spring 2010 회원
CPSU-REGAN-S10S26G34
4 회원들
안내서 13개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 2
전체 시간: 1,709
